yesbut you still have negative 66V on the collector of TR10, correct?
Discovered an invisible hairline fracture on the F-2508 connection to the last Molex pin. You can see the pad lifted.
Collector of TR10 to that last Molex pinJust for my own sense of sanity, was that your test point when measuring voltage on R16 ?
Ok thanks, that explains a lot.Collector of TR10 to that last Molex pin
Thankyou John, that was some weird ride!Well Done Brad! and Richard!
That is one peculiar fault, flips to a positive voltage when open circuit.![]()
Thanks John and Richard! So much going on tracing the source of output failure. Some silly errors on my behalf during the diagnosis ! Lack of sleep. Anyway, problems solved. Thanks for hanging in there with meWell Done Brad! and Richard!
TR04 2SC1735 was the root cause of the recent issue. It looks like it had failed (reading as a diode), case cracked, causing the negative 35V rail to fail on the regulated PS. It likely caused a spike to the drivers, knocking out 2 x 2SC1735 and 2SA908 Sanken outputs.
