Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Failed TR04 - reading as diode B-E with C not recognised. Looks like the case has cracked too. This, along with all the other transistors were removed and tested as part of the restoration. I do like to stick to the known problematic only when choosing to replace them, however in this case, I'm going to repalce all the small transistors on the F-2508. I no longer trust them - all have the black silver oxide leads. Shame as the originals are a lot faster but it is what it is. I'll go through them all and research replacements. Will update soonest.
Been following - one thing is bugging me. To get the +66 volts you have to have -66 volts at the end of R16 (10 ohms). That point is a continuous trace to the -66 volt output pin with the missing voltage. Either there is a crack in the trace, or a bad connection at the -66 volt output pin.
If it's been resolved, I must have missed it.
Didn't install the diodes. All small BJT's installed correctly, double-checked to SM layout and silkscreen. Will remove and test TR10 and TR05 again as the failure of TR04 may have knocked one of them out
