Glenn, we've both been members of this site for virtually the same time. I am stating a fact here, the same postings on the same subject keeps coming up with the same responses- none of which tackle the issue. Capacitors are just one of many components all susceptible to failure. Not only that, many people cannot test the caps properly, don't own an ESR meter and really have no idea whether they are OK or not. I have seen hundreds of postings where the standard response is 'recap the amp' when the problem is clearly unrelated. I like you, use good quality caps and where possible original caps whenever I replace, but blanket replacements are not clever (and may merely obscure the real issue), especially when 9 times out of 10, the 'restoration' doesn't involve all the caps because they are too hard for the 'tech' to find. My point is, why stop with the caps? The carbon/brass cap resistors or epoxy case/carbon resistors are a candidate too, as is every transistor. You know as well as I do the small signal T092 transistors shift their gain and noise characteristics more than most other components put together.
I know the real reason, caps are easy to replace. A novice with a soldering iron and a bag of caps and a day to waste, just may possibly fix the ageing amp with the hit or miss approach. Then again, he may also be convinced the amp sounds better too. How about some actual data here? I don't attack anyone, merely practicses that have dubious merit, no measured data before and after, little logic and are surrounded in a sea of self perpetuating folklore. :thmbsp:
