If you want to want to comment on a post, you will see the "quote" button in the bottom right corner, if you hit that, it will put that post in a quote box and then you can write your response outside the quote box.....
When you are typing your response it will show like this below...
Having owned and helped members here with various G22000/33000, they do have funny little issues that pop up, usually nothing serious....
They can have a few issues with the protection circuit....
Some of the switches and controls can get a bit intermittent and unreliable, but mostly these are things you can tackle easily yourself....
I find if its in daily use and the inputs are switched daily, and every now and then you work the controls they are very reliable....
If it ever starts to drop out on one channel or has and uneven level between left and right, it will be the "connected/separated" switch on the left hand side of the pre-amp, this is usually the first one to play up....
But hey exactly, if she is a "mint runner", absolutely enjoy it!! they are a beautiful sounding beast......
I dont know if you are into using the tuner, but the FM tuner section in this thing is one of the best I have heard, exceptional actually......Mine is used daily for high quality FM listening....
