sansui g 22000
georgedannyg
Well-Known Member
after i get done with my au 717 sansui am thinking about changeing my adjusable pots on my driver boards on the sansui g 22000 what kind of pot should i use
For the driver board the bourns 3296Y series is what you want. They are available at Digikey. On the G22000 there are also adjustments on the flat amp and equalizer amp circuit boards. If you want to change those you need the 3296P Series
The DigiKey part numbers are
DC offset pot driver board 3296Y-101-ND
Bias Pot Driver Board 3296Y-201-ND Note: this is a 200Ohm pot the original is 220 but this works just fine.
DC Offset pot on Equalizer Board 3296P-101-ND
DC Offset pot on Flat Amo 3296P-201-ND Again this is a 200 Ohm pot the original is 220.
They are about 2.50 each for the 3296Y and 2.70 each for the 3296P
You are looking at about $20 from digikey,
Have fun.
Gotta love them Big G's
You will need two of each of each one.
