We have just been discussing this in another thread about the AU717.
The MJ21193 and 94 will make the amplifier work, but they are not suitable replacements as they compromise the performance of the amplifier due to the fact that the original transistors are 20mhz devices as opposed to the 4mhz of the MJ21193/4.
The speed of the amp is compromised, TIM Distortion, THD and slew rate are all compromised. It makes a definite audible difference and you lose the performance the direct coupled high speed Sansui amplifiers are famous for.
There are no TO3 devices currently manufactured which fit the spec's.
The only two options are to buy NOS, there are transistors out there if you look hard enough, or you can buy new TO3P Sanken transistors from Digikey and with some small modification, fit them to the amplifier. Search out my BA-F1 thread to see how I did it.
I have done this to G9000's, G22000's, AU517, BA-F1 with great results.
Download the Datasheet for the original transistors, then go to digikey and search out the closest specs.
