It’s been fun! And glad I can contribute something here.Haha! Well thanks for taking the time to do this. It's good to know about!
Got it and amended. Thanks!@JimEGR - I missed out two models in my original post back then:
JDM --------> International
AU207II ---> AU-217II
AU307II ---> AU-307II
Unfortunately I am unable to edit my original 2020 post to add these
Are all the "First Generation" amps in your list cap-coupled? I think some of them are direct coupled (such as the 999, 888, 666), which would further subdivide your list.
Great project, following this with interest. I wonder if anyone has done the same with receivers?
Excellent resource! Charts the lineage from the AU-707 with great detail. It looks like the AU-707 was released in 1976(I updated the date in post) but the AU-819 international equivalent not until 1978...?This site is also quite nice. Please check it out. It features some information about the latter models.
But it is also worth reading the main page where there is a more comprehensive list of brands and models of various audio equipment modules.
There may be some dissagreement among sources. Perhaps the most reliable way to know when each model was released is to look at the serial number database compiled and maintanied by @LBPete. Looking at the listed models in the file one can empirically determine when models were produced because this information is encoded in the serial number.
EDIT:
This document
I am not sure if is up-to date. There may be other files. Kudos to LBPete who is doing a formidable work.
AU-707 = AU-717Excellent resource! Charts the lineage from the AU-707 with great detail. It looks like the AU-707 was released in 1976(I updated the date in post) but the AU-819 international equivalent not until 1978...?
Comparing your list to the Serial Number Database, some dates are a little off. This is based on serial numbers we have on file.Thanks for the links and feedback. Trying to understand the models, series and design/engineering development over time.
Starting with what I believe are the first solid state integrated amplifiers, does this list look correct?
First Generation SS Integrated Amplifiers
AU-777 1967 25 watts
AU-222 1968 18 watts
AU-555 1969 20 watts
AU-777D 1969 30 watts (JDM - Japanese Domestic Market version of AU-777A)
AU-777A 1970 30 watts
AU-666 1970 35 watts
AU-999 1970 50 watts
AU-555A 1971 25 watts
AU-888 1971 45 watts
AU-505 1972 12 watts
AU-101 1973 15 watts
Sources
https://audiokarma.org/forums/index.php?threads/a-list-of-sansui-firsts-a-little-history.926506/
https://sansuisound.com/about/22-en.html
http://www.sansui.us/PG_AU999_Series.htm
https://www.classicaudio.com/value/san/index.html
https://audio-database.com/SANSUI/amp/index.html
https://www.hifiengine.com/manual_library/sansui.shtml
https://ishinolab.net/modules/doc_serial/index.php
@Sansuiman
AU-777A 1970 30 watts -----Earliest production on file is September 1969
AU-555A 1971 25 watts -----Earliest production on file is June of 1970
AU-888 1971 45 watts -----Earliest production on file is October 1970
AU-101 1973 15 watts -----Earliest production on file is March of 1971, there are also two on file that show December 1970 but they might not be accurate.
Hope this helps.
- Pete
Integration and continuation of post #9. Getting a better understanding of the Sansui power evolution. At this point I am up to about 1979. There is no way I got all of the dates correct - crawling across the web the release date on each of these pieces seems to vary 1-3 years, depending on the source.
Feedback? Corrections? Should the generations be more granular based on significant design/engineering differences?
- - - - SOLID STATE INTEGRATED AMPLIFIERS THROUGH 1979 - - - -
--- Second Generation ---
1972 AU-9500 75 watts
1972 AU-6500 30 watts
1972 AU-7500 32 watts
1973 AU-8500 60 watts
1974 AU-4400 20 watts
1974 AU-6600 42 watts
1974 AU-7700 54 watts
1974 AU-2200 10 watts
1974 AU-7900 80 watts
1975 AU-3900 25 watts
1975 AU-4900 38 watts
1975 AU-6900 60 watts
1975 AU-5900 45 watts
1976 AU-2900 15 watts
"Professional Series"
1975 AU-9900 80 watts
1975 AU-11000 110 watts
1975 AU-20000 170 watts
1977 AU-9900A 80 watts
1977 AU-11000A 110 watts
--- Third Generation ---
1976 AU-317 50 watts (one serial number 836042910 04/1976)
1977 AU-117 15 watts
1977 AU-517 65 watts
1977 AU-717 85 watts
1979 AU-417 65 watts
1976 AU-607 65 watts (JDM version of AU-517)
1976 AU-707 85 wats (JDM version of AU-717)
1977 AU-207 30 watts (JDM version of AU-217)
1977 AU-307 50 wats (JDM version of AU-317)
1978 AU-317ii 60 watts (one serial number 838080677 08/1978)
1979 AU-117ii 25 watts
1979 AU-217ii 40 watts
1979 AU-107ii 25 watts (JDM version of AU-117ii)
1979 AU-207ii 40 watts (JDM version of AU-217ii)
1979 AU-307ii 60 watts (JDM version of AU-317ii)
1978 AU-919 100 watts
1978 AU-519 70 watts (one serial number 228090437 09/1978)
1979 AU-719 90 watts
1979 AU-819 90 watts
1978 AU-D607 70 watts (JDM version of AU-519)
1978 AU-D707 90 watts (JDM version of AU-819)
1978 AU-D907 100 watts (JDM version of AU-919)
1978 AU-D907 Limited 100 watts (JDM only)
--- Fourth Generation ---
1978 AU-X1 160 wattsl
I'll check the rest when I have more time.
- Pete
@JimEGR, since you have already taken to noting JDM specific models, you may wish to notate that the BA-100, 150 and CA-606 are all JDM models with no international equivalent, as they are all 100V only. Oddly, the TC-505 preceiver is also a JDM model judging by it's short FM band (76-90 Mhz) but at least some appear to have been equipped with selectable voltage. It is a contemporary of the AU-555.
The TAC-505 receiver (not presently on the list) was also a JDM model, and a contemporary of the 555A and 666, so the production dates should align fairly closely, I'd think.
AU-707 = AU-717
AU-D707= AU-819
On the Ishinolab website you can find some more useful information. For example, apparently there was a big Hi-fi show in Oktober/ November where they would try to launch new model lines for all the attention it would get in the press and to start selling to the shops that would visit.
That's why the AU-D907 was launched in 1978 and the AU-D607 and D707 in 1979. They wanted the TOTL model ready for the show even when they did not have the whole lineup finished.
I think it was also the reason why the AU-X1 was released prematurely. There is a nice story where they get a lot of calls after a few weeks it has been for sale with blowing up outputs. Apparently they went to far in minimizing the compensation capacitance on the transistors and did not take the time to test it properly. Mr. Ishino himself with other engineers had to go to the buyers homes to repair them. Great story, took them a couple of weeks to fix all of them.
By the way, I noticed you have the release year for the AU-2900 on 1977, accidentally I just posted the serial number of mine which is from December 1976.
