SANSUI RECEIVER,lights out
rudpra
SANSUI SEVEN everything works,but all lights are out have checked all fuses and they are OK,?? causes,solutions......thanks...
May be wired in series..One lamp burns out ,they all go out.
I'm not sure, no schematic in front of me.
If its similar to the model 8..they are parallel and series. There is a single fuse for all lamps F008 (check it with a meter!!). otherwise it could be a bunch of bad bulbs,dirty input selector switch,broken wires or bad connections.
Sounds like lamps to me.
Not sure about the Seven, but my old G3000 had the dial lamps wired in series. One burned out, the whole dial went dark.
PM AK member dgwojo...he is the go-to guy for pretty much all your vintage lamp needs.
EDIT: I type slow.
New member,have read the rules,but things happen when you want to fix your stereo,thanks.....
