Sansui Serial Number Database Update
Thank you sir! Your AU-555A was built on production line 83 in March of 1972. It was the 347th unit off that line that month. During March '72 line 83 was also building QS-500s and AU-101s.
- Pete
Thanks guys, they will be in the May report available in early June
AU-7700,814102634,jmjrcv
Yes, it's an addiction :)
Your AU-7700 was built on production line 81 during October of 1974. It was the 2,634th unit off that line that month. Line 81 was also producing AU-7500s and AU-6600s that month.
828071380; G-5000; jjirons69
Your G-5000 was built on production line 82 in July 1978. It was the 1,380th off that line that month. Line 82 was also producing G-6700s, G-2000s and G-301s that month.
In the future when you post a serial number please use this format: G-5000,828071380,jjirons69. I process hundreds of serial numbers each month. Having them all in the same format makes them easier to compile and process. Thanks!
- Pete
I appreciate it, Pete. Very cool information. Sorry about the formatting. I guess reading hundreds of these didn't help me any :).
331,027010636,Scott Muni
Later model build with vent on cover, and additional heat sink for STK module. Also has white area around signal meter, some are blacked out.
2000,18053994,ohmegaman
2000a,820031281,ohmegaman
551,26070734,ohmegaman
QR4500,822011026,ohmegaman
6060,858032054,ohmegaman
7000,221073870,ohmegaman
Thanks for maintaining this database!
Oops, I see that my last entry is a duplicate. I didn't realize that the seller was another AK member who had already submitted the serial #.
@Scott Muni I'll put that additional detail in as a note. It won't show on the monthly report but it provides good detail on timing of production changes. Thanks!
@ignoramustot, I have yours from the other thread. No need to post it twice.
@jmjrcv your AU-719 was built on production line 22 in April 1979. It was the 541st unit off that line that month. Line 22 was also building AU-D907s, AU-D707s and AU-919s that month.
Your 2000 was built on Line 01 in May '68. It was the 3,994th unit off that line that month.
The 2000A was built on line 82 in March of '70. It was the 1,281st unit off that line that month.
The 551 was built on line 02 in July '77. It was the 734th unit off that line that month. Line 02 was busy that July. It was also building TU-5900s, AU-3500s, AU-1500s and 5050s
The QR-4500 was built on line 82 in January '72. It was the 1,026th unit off that line that month.
The 6060 was built on line 85 in March '78. It was the 2,054th unit off that line that month. Line 85 was also building G-7000s and G-5000s that month.
Your 7000 was built on line 22 in July '71. It was the 3,870th unit off that line that month. Line 22 was also building QS-1s that month.
Thanks guys. Every serial number makes the database better!
- Pete
- Pete
thanks Pete, my apologies for posting it twice. I wasn't sure which of the two threads to post it in. Which thread is your preferred one to receive these?
thanks for your work on this,
Rob
AU-719,229041403,TKPDX
My First Sansui. Needs a bit of TLC, but should be back on her feet soon. Thanks!
Tom
