blues 66
Hey Danzilla,
Welcome! If you glance through this thread, more towards the beginning, I tackle the crossovers with new caps. Ultimately, the fact that you replace your original caps with new ones will make the most difference. Dayton Audio, Solen, whatever poly caps, are all fine choices. I generally buy mine from parts express. I'll go with whatever brand makes the value that I require.
These crossovers are a moderate level of difficulty. The crossovers are on a circuit board, which is affixed to the plastic cup that holds the binding posts, screws into the back of the speaker. In this thread, I describe how to separate the circuit board from the plastic cup. At the time, this was the only online mention of being able to separate the two. I was pretty proud of that. However, you can simply snip the caps closest to the capacitor. This leaves some of the lead coming out of the circuit board. You can tie the new caps to the existing leads, this is an acceptable route.
As far as repairing your grills, I would suggest starting your own thread and including pictures. Without pictures, we're just speculating on what method would be best. And that doesn't do anyone any good.
Biggles
hi Biggles, it's always nice to see the interest ... of the Sansui SP 3500
now I'm ready, I bought the new capacitors, unfortunately they are 100v in polyester, not polypropylene.the important thing is to change those old condensers, 40 years ago
reading your post, I read (highlighted in black) that you can, cut the caps closer to the condenser.
and if i did something like that? so it could go
thanks
