Looks like I need to take the Kenny Quad home and hook her up.
I will have to agree, sir. I'm getting antsy here, got my nose pressed to the window waiting for the UPS truck.
Biggles
Well since your a pro now with the recaping you want to do mine? The 3500 & 5000, Im sure I have something you want here![]()
nice write up on the progress of your 3500's, i just brought a pair of these home, a 1 owner pair, original owner brought them home from Japan in 1970, and has never had the grills off, now my problem is i cant get them off, is there a trick to them ? feels like if i pull any harder they are going to break, are they just that hard to get off ? been trying to see any close up pics on how they are attached.
lmao:dstop !!! get a flashlight, quick! In each of the 4 corners is a very very tiny black screw with a philips head. You can find them, go!
They'll fall out after that.
Check the cloth surround and make sure it's adhered well to the paper cone. Then plan on replacing the capacitors, pronto.
Biggles
STOP !!! Get a flashlight, quick! In each of the 4 corners is a VERY VERY tiny black screw with a philips head. You can find them, go!
Biggles
Yeah, I spent most of the morning peeking my head out the door waiting for the UPS truck. It came and went with no heavy box. So, I figured that was a sign to get my squirrelly butt to work and get things ready.
While getting the surround glued back down, got the veneer on the enclosure cleaned up. The lacquer is actually pretty okay, cleaned up nicely. Other than new capacitors (after the sound check), these are going to remain in-play for a while. When I have nothing else to do, I'll pull them out and strip n refinish.
Biggles
what glue did you use for the surrounds ? and thanks again for the info of the grills, got them off and see that i have a couple places that need re glued
Hi, I just picked up a free pair of the SP-3500s. Of course the surround is coming off and stiff. I can easily glue the surround but did you ever figure out a good way to soften them up chemically? How about a 30 hz tone for a while?
Hi Pepito,
What exactly are you wanting to do to the grill? Are there missing pieces of wood, broken snapped bits? Stains, water damage, paint?
As you can see, the detail work on those grills is insane. Sanding, wood bleach and a new finish would be an insane job and you'd never see the monetary return on your efforts. What we generally do, is wait for a replacement to show up on fleabay and simply replace them.
Just to wash them with wood soap and oil them up is quite a job. We're talking tooth brush and time.
Biggles
