I just did up some efforts on the bottom of the first enclosure. Am wanting to take my time, be a little patient. The lacquer and veneer on the bottom of this enclosure was pretty darned trashed, as you saw in the last image. I had planned on using a chemical stripper for the lacquer, but with all the exposed veneer, I decided to just use the palm sander and see how that went. It was very easy to see when the sander was sanding the lacquer versus the veneer. As soon as the veneer began to show up, I stopped. Veneer exposed.
I've got some clean old t-shirts, so got one wet. Set my wife's iron to high and worked on the scratches to see if I could raise some of the old wood.
Some of the veneer came back, sort of. But there are portions of the veneer that's missing. And some of the scratches are so deep and nasty, there was no wood left to raise.
I'm not done with it yet. I started with 80 grit to get the lacquer off. Yes, that was too much. But it was already on the sander and had been used previously, no harm done. Once the ironing was complete, I hit it with 200. That evened things out a bit, so I wiped it with mineral spirits to see what it looked like.
BEFORE:
AFTER:
Wow, I just love the smell of wood being sanded. And walnut is so unique, tasty!
Biggles
