Hi again: still pondering how much better, if at all, a Yamaha PF 800 (or 1000) will sound than my existing Sansui SR-838. After reviewing the specs, the only differences I see are as follows:
PF800 vs. SR 838:
Drive Belt Drive Two-speed vs. quartz-servo, direct-drive, manual turntable
Platter 0.86kg zinc (inner), 1.63kg aluminium (outer); 2.49kg total vs. 318mm, 1.7kg, aluminium die-cast 350mm
Signal to noise ratio better than 80dB vs. better than 64dB
Wow and flutter less than 0.028% WRMS vs. less than 0.025%
Pitch/fine speed more than +/- 6% vs. +/- 2.5%
What spec or other consideration might influence the sound quality than the above? Thanks for your insights and help! S p.s. I'd likely be using either a Soundsmith Otello ES or a Ortofon Bronze on the Yammie, since those I have now.
