The reason
Very respectable tuner - not quite at Sansui's best but not far short of it. Looks gorgeous and sounds pretty damn fine too. The attached brochure refers.Is the Sansui TU-7700 a respectable tuner? I just picked one up today...exterior was in great condition. Any insight would be appreciated. thanks
last post on this thread was 9 years ago, and I can't recall seeing this member around for quite some time....Always check the dates before replying.Very respectable tuner - not quite at Sansui's best but not far short of it. Looks gorgeous and sounds pretty damn fine too. The attached brochure refers.
Nice pickup!
Like kevzep just said (please read his post), this thread is 9 years old. The OP is not going to see your message.the 7700 has to be a pretty rare model. At one time, I had every piece Sansui made as far as tuners and amps. Would guess the 7700 is the forerunner to the TU 717, but a guess only.
on yours, would suggest as a min, to re cap the power supply. I have worked on quite a few of the Sansui and Yamaha tuners. power supplies are usually pretty straight forward and not too tough to get too.
best
Wow !! It’s the perfect match looks great together
Another great matchup. !!View attachment 1577471 This doesnt look too bad and sounds great, Ill have to fix that light though and clean it properly.
I ordered a bunch of 10 x 3mm and 10 x 5mm pre-wired blue LEDs for my TU-7700 and TU-5500 from fleabay for about $10 they have a resistor in series covered with shrink wrap with 20cm leads all ready to connect to the 12v on #1 fuse. This will fix the glaring white light and make the tuner look cool at the same time.
