TigerScent
Hey TigerScent - details on removing pot? I have a 2.0 version & use it in the tape loop of my pre. Recently swapped out the 5670 GE 5 stars (which were a big upgrade from stock) for some Sylvania 5670s. They sound better yet.
hmmm, trying to remember now ... After taking the top red cover off; I was placing tension on the potentiometer to pull it off the board as I was applying heat, to various parts of it. I think I was partly successful and parts of the pot lugs that tore off I just desoldered removing with tweezers. Then its just a matter of logic in determining which parts should be hardwired together as per the pot connection, ie: so where the pot is inbetween to cause variation, you just hard wire that particular connection. I used the best Mundorf silver solder - works for me ... its a super little unit for the price.
The less inbetween the signal the more direct and accurate the sound reproduction...In addition, will be removing the RCA input/output terminals and just solder some silver plated microphone wire as interconnects straight from the Guanzo, in and out, so that there will be only RCA's on the ends of the cable from the Guanzo..., that will plug into the pre-amp/amp connections...
(Will be putting together a Jadis JP200 preamp clone soon...from 'Analog Metric' --- looking forward to that, but just need to find a way of making the output under 100 ohms, preferably about 10 ohms. Don't ask 'why', I just need solutions on how to do that without compromising the sound on any level, so if anyone knows how, suggestions are most welcome...)
