Lavane
Lunatic Member
Ya, they probably should be replaced also.I've never seen any discussion on Packaged Electronic Circuits, the proto IC's that are in various Dynaco amps. They contain capacitors and resistors that I assume set values for the tone controls. Should they be replaced? I always wondered about these but never have seen any focus on them. You can find NOS with PN 555003. Safe to assume that the capacitors inside are some sort of ceramic type build? I ordered some to investigate. Maybe I can pull some values from them and we can experiment with wiring up discrete components instead.
The ceraminc caps inside are probably ok, but the resistors are all carbon comp. You can make your own using COG capacities and metal film resistors built on small pieces of perforated project board. I replaced the PEC's in my FM3 tuner with some built that way.
You can cover them with large diameter shrink tubing, or dip them.
