Update - driver boards completed, messed around with some nos 6GH8A's with an adapter and was not disappointed. Using my emissions tube tester I compared the state of my 7199 collection to a lot of RCA 6GH8A's that I was able to get very cheaply, well the 6GH8A's tested like 100% while the 7199's were all a bit worn out but still in the good position (but closer to the ?). The tester was kept configured for the 7199, and I tested the 6GH8A's with adapter as if they were 7199. I know I was considering rewiring the sockets for these type tubes, but I bought an ST-70 that came with these very nice gold plated adapters and they work beautifully. The 6GH8A's with adapter are audibly indistinguishable from my best testing RCA and Sylvania 7199's, can't tell a difference and neither can my scope.
The orange caps I used are overkill 800v rated 0.1 mf coupling. All resistors are Vishay and individually selected based upon their role in the circuit, most are 1% tolerance, high voltage / pulse rated. The lower voltage 0.1 mf ceramic cap was replaced with a 100v wima I had on hand. 12pF cap was replaced with 1kV USSR components I had left over from the Mark 3 builds I've been doing. They're fantastic.
I LCR test all components that I remove, and all I put in. Around half of the original resistors on the driver boards were like 30%+ out of spec, some were really bad. It's really impressive that the circuit still worked. The other half of the resistors tested very accurately, I'll save them for guitar pedals and other fun projects.
Up next I'll be replacing the capacitor cans as in my listening room I was able to perceive a low hum, these original cans are done. I'll replace the solid state rectifier section at the same time as they're all interlinked.
Finally, when selected the phono section has a very audible 60 cycle hum with nothing connected. I have tried adjusting the hum pots. So I'll be focusing on that board and its wiring, I can see that someone tried to modify the wiring of the phono section with ground shielded speaker wiring and I'm guessing that's the issue, it's so bad.
