Yes I was able to by using a heathkit signal tracer that I rebuilt. About the most useful tool in my arsenal now, you just hook one end of the probe to signal ground and you can follow the signal path until you find the stage of amplification producing the noise. I think I saw that you're using Gillespie boards so this would be a great way to solve your issue.I'd be interested to hear if you resolved the problem with hum on the phono input.
I'm listeningWe bought a supposedly properly working Dynaco SCA-35 on eBay - the tone control circuitry had been removed, other parts are modified, and it doesn't work as an amplifier. (It seemed pretty well packed, so not sure how much of the trouble is shipping damage.) Saw another ad with pictures of 555002 parts, which look like what's needed to restore the tone controls. I'm a new audiokarma.org forum member today, and hope I can figure out how to talk to Peter.
what are the speakers?View attachment 3498034
Did some bluetooth streamer testing tonight, it's sounding very sweet. I love this circuit.
Someone recommended you as a source for 555002 circuits, ours are missing, can help? Also, what's your best source for schematic & maintenance documents?I'm listening![]()
Yes i have made a clone of these. They are significantly smaller, built on a board using surface mount components.Someone recommended you as a source for 555002 circuits, ours are missing, can help? Also, what's your best source for schematic & maintenance documents?
Dynaudio Emit 20's I think there. They're a fantastic pairing with tube amps from 20-150 watts, for example great with EL34 / KT88 designs too. Very good bass response, no need for a subwoofer, easy to listen to and very detailed. Delightful.what are the speakers?
Thanks for your reply to my question. I've been offline for a few weeks helping a family member move and so just seen it now. As it happens, I recently bought a Heathkit AV-3U AC Valve Millivoltmeter for similar signal tracing purposes, so I'll return to my SCA-35 to investigate.Yes I was able to by using a heathkit signal tracer that I rebuilt. About the most useful tool in my arsenal now, you just hook one end of the probe to signal ground and you can follow the signal path until you find the stage of amplification producing the noise. I think I saw that you're using Gillespie boards so this would be a great way to solve your issue.
My model is the IT-12. I used the following kit which is easy to find to replace the can cap and other components. I really admire the design of the can cap replacement board so I grabbed it, but you could just wire it up without honestly. It's a great kit none the less. Comes with parts to restore the probe components and sticker too.
I know it's extremely dangerous, but nothing beats a plate of copper wired to ground that you can manipulate around the circuit. If you're lucky enough you'll shield the hum if it is being induced. There is always the possibility of power supply hum too so you're set for a workbench adventure.Thanks for your reply to my question. I've been offline for a few weeks helping a family member move and so just seen it now. As it happens, I recently bought a Heathkit AV-3U AC Valve Millivoltmeter for similar signal tracing purposes, so I'll return to my SCA-35 to investigate.
A lot of the advice that is given here assumes common sense, and I realize that was an especially bad comment to make without making it clear the plate should be covered, thank you Gadget. Sometimes it feels like it's just a few of us in here but audiokarma gets half a million visits every month.if you're going to do that, I'd suggest insulating the copper plate to at least make it less likely to short out on things. Even just a layer of electrical tape will be better than nothing. The good stuff is rated for 600v per layer.
