hi*ball
Records & Coffee
That's very cool of you to offer, thanks. I think I'll go ahead and buy a qty of each since I need them either way.
Mofi all the way, as far as they bunch up..yes it might take an attempt or two on the odd album..you can tell if it is bunching and just need to finesse it in.Like I said, I have read several threads on the subject (here and elsewhere) and I've repeatedly seen comments about the MoFi sleeves bunching up due to lack of rigidity and several people have used the SleeveCity as a good alternative. One thing I want to avoid is the plastic bunching up inside the jacket. That's been one of my pet peeves for decades when I have an LP with plastic inner sleeve.
Fear is the little death that brings total obliteration.Fear is the mind killer.
I need some inner sleeves to replace the paper scuffers... After searching through some threads here I'm hesitant to buy the polylined sleeves for fear of hazing etc.
Is there a definitive answer as to which inner sleeves will resist scuffing better than normal paper sleeves without harming the vinyl otherwise over the long term?
I'm not looking for low budget solutions, but I'm not on a cork sniffer budget either.
Thanks,
-Jeff
Yep. What they ^^ said. I've been using them since the 70s with zero issues
I see the benefit in preserving the sleeves with this method, but I like the security of having the cardboard protecting the playing surface. I'm pretty careful, but things do happen. And the vinyl is worth more to me than the sleeve.I have thousands of MoFi sleeves in use. Likewise the DiskKeeper Ultimates. I consider them equivalent, even though there is a difference in the paper core weight. I never re-insert them in the jacket anyway, so that is a moot point. I use an outer sleeve, and the record sits behind the jacket.
The poly-lined paper ones from Sleeve City are a good alternative, at a bit lower cost.
In the end, each person does what is comfortable for them, and their budget.
