malanga
Well-Known Member
I found this Fisher 674 at a thrift store today. Does appear to be working, but I think the stereo light is burned out. Never heard of this particular line. ANy knowledge shared would be most appreciated.
The Columbia SQ Quadraphonic system was the most popular of the quadraphonic matrix style formats. Matrix style formats allowed record companies to fit four channels of information onto two-channel media. That is, a four-channel master was fed into a matrix encoder that created a two-channel encoded master. The encoded two-channel master could then be manufactured (LP and tape) just like any other two-channel media. The end user would play these encoded two-channel media into a complimentary matrix decoder to recreate four channels of quadraphonic sound.What exactly is an SQ decoder? :headscrat
Did you get any more specs on this unit? I happened to get one recently and was wondering what all it had in it. Also, the writing for the positions on the far left dial on my machine has been warn off. Could you post a picture of that side of the machine? ThanksI found this Fisher 674 at a thrift store today. Does appear to be working, but I think the stereo light is burned out. Never heard of this particular line. ANy knowledge shared would be most appreciated.
The "Disc Out" jack is the FM radio discriminator output. It was included on many quadraphonic receivers of that era. It was provided in preparation for the time when a quadraphonic FM broadcast system would be approved by the FCC and implemented by the broadcast industry. The concept was that FM radio stations would encode quadraphonic source material for broadcast. On the receiving end an external FM decoder would take the FM detector output and decode the signal into four channels. Although such a system was designed and field tested, it never made it to commercial use.What I wanna know is, what's up with that "Disc Out" jack(?) on the back, fourth pic in your original post......
A standard two-channel turntable with a standard two-channel stereo cartridge plus an amplifier, receiver or preamp with a SQ decoder is all you need to properly decode SQ (or QS or Stereo-4) encoded quadraphonic records. Matrix quadraphonic records will never produce fully discrete quadraphonic sound, however, they can sound quite good. For discrete quadraphonic sound you would need a Q4 (quadraphonic reel to reel), Q8 (quadraphonic 8-track) or a CD-4 (quadraphonic LP) playback system with suitable software.If a standard 2-ch turntable with a standard stereo cartridge is used as a 2ch source going into an amp with SQ capability (like this one) and four speakers (front left and right, rear left and right) can it put out discreet four channel sound?
