... The amp came with 6BQ5 tubes in it instead of 7189's, a definite no-no, but I'm not sure that would have contributed. ...
I thought the same, till Dave Gillespie explained that it is quiescent dissipation (taking current as well as voltage into account) that is the important factor. He was commenting on the fact that my 222C also came with 6BQ5s. I'll copy his comment here, because it's really instructive and because the 299B is pretty similar to the 222C.
Dave writes:
If I may -- the reason that the output tubes have lasted so long, is because the LK48/222 series of amplifiers are in fact quite easy on the output tubes.
It is easy to get caught up in voltage concerns -- particularly with 6BQ5 class tubes -- and look a circuit with 400+ volts applied to the plate, and make the conclusion that because of the high voltage, either 6BQ5 tubes absolutely cannot be used, or it is running 7189 tubes right at the limit, and so the unit is very hard on the tubes. But if so, then there's a huge disconnect because in the case of the amplifier at hand -- and the many I have run in to -- the tubes seem to live a very long life indeed. It's not because my own LK48B-C1 came with premium Telefunken power tubes.
Voltage rating is important -- as it relates to catastrophic failures. But even those are published as guidelines. Yet if the appropriate precautions are taken -- which Scott did -- then those voltage ratings can be exceeded (within reason of course) without fear of internal breakdown or failure. Clearly, history shows this to be the case, as this series of amplifiers is not known for the output tubes having fits of melt down if it has been properly maintained.
If fact, over time, given a proper design and typical home use, it is the steady state dissipation level (a product of voltage AND current) that is the primary life determining factor for the output tubes. Type of use can come into play as well if large amounts of power output are expected on a continuous basis. But in a typical home application, by far, it is the steady state dissipation level that is the main determining factor.
Now ALL tubes within the 6BQ5 class of tubes have either a 12 watt plate dissipation rating, or a 13.2 watt rating, depending on whether you're looking at data published under either the older Design Center, or the newer Design Maximum rating systems respectively. 6BQ5, 7189, 7189A, EL84, it doesn't matter. Yet based on the design of the (somewhat goofy) bias adjustment switch of my model, the circuit intends to operate the output tubes at just 20 ma of quiescent current each. If you allow that about 2 ma of this is for screen current, that means that the plate current is only on the order of about 18 ma. At a plate voltage of 420 volts or even more, this represents a plate dissipation of not even 8 watts, or operation at about 60% of the Design Maximum rating for the tube. This is extremely conservative operation.
I'm not sure what the exact bias procedure is for your specific version of this model platform, but in any event, it won't deviate significantly from the overall results described here.
So while voltage rating IS important as it relates to specific circuit design, once that is established however, it is the steady state dissipation level that is the huge life determining factor for the tubes in the design. In at least this example of Scott engineering then, the output tubes should last a very long time indeed!
