Hey, Dandy. Well, I'm wondering too, because I've heard the Pyramid "black beauties" are worse for failure than the Ceracaps. These are 0.0012 uF 400 VDC caps. I have 0.0010 and 0.0015's handy. Can I use either of these if I decide to replace, or do I need to use exactly 0.0012? I hate to 2nd guess the engineers! No balance or sound issues at all with these Pyramids in place.
Here's another question for you; a bit of a mystery at least to me. I put the amp on the scope and was testing the old tubes after balancing and biasing them and one set had a bad one in it. I looked at the tubes and had 3 definite 6BQ5's and one "different" that might have been an EL84 or even a 7189 (markings gone). The odd tube was the bad one. So, I decided to put in a new matched quad of Sovtek EL84M's, along with two NOS 6BL8 PI/Driver tubes. Well, I couldn't get the Sovtek's to bias to full cathode current, even with the pots turned all the way CCW. The spec is 55 mA for each pair, and I was shooting for 51 mA. I could get one pair to 51 mA cathode current barely, and the other I couldn't get much past 40 mA. I had reset the DC balance for both pairs.
I tested output to clipping on the Sovtek's and still got 18.5 watts in each channel--pretty much full output for this amp. I decided to put in some known old tubes to see what happened and installed a pair of the 6BQ5's and a pair of tested good Sylvania black plate 7189's I had on hand. No problem biasing either pair at all! Went easily to 51 mA with plenty of room on the pots, then power tested at 18 WRMS for the 6BQ5's and 19 WRMS for the 7189's.
So what gives with the Sovteks? Do I need to let them burn in a while? The sound check on the Sovteks sounded fine to me. Can I run them this way, since I'm getting full output power? Appreciate any thoughts from you or anyone else watching. Dave
