Servicing a Thorens TD160 super w/pics
I picked up a Thorens TD160 Super from the original owner that had been sitting for around 20 years unused, and it arrived yesterday.(pic 5) That is a story all by itself and can be checked out here:
http://www.audiokarma.org/forums/showthread.php?t=362767
So today I went about serving the table and bringing it back to it previous glory, and thought I would go through the process step by step since many here have TD160's
Lets start with the differences in the TD160 Super from a standard one. As you can see the bottom plate is very heavy compared to the Masonite one on the Std TD160.(pic 1 and 2) Also the plinth is more substantial, and the bottom of the top plate and bearing/arm board plate are dampened on the super. (Pic 3)There is no foam in the springs, and the arm board is made of a heavier material as well. The bearings seem to be the same, however the outer platter is a bit different and this one had the guard in place to prevent the inner platter from being removed. (pic 4) Also as with most of these tables the bearing had hardly any oil left in it. Continued....
Jim
Jim
