rolleiman
Hi Team,
Just purchased a Sherwood S-5500 II (7591 Tubes) and plan to restore it but have been staring at it for a week or two and not quite sure where to begin. What I have done and observed so far:
- I brought the unit up very slowly without the output tubes to ensure electrolytic got conditioned a bit before full power was applied.
Question: is it a bad thing to run amp without output tubes installed. I observed voltages after the input diodes feeding the voltage doubler higher than I expected. 506 volts. Schematic says it should be around 370V. Looks like largest rating on the can cap section is 400 Volts. Explanation?
- Power cord is of course old and cracking. I have a bi-polar plug I cut off some newer equipment that has18 gauge wire and says the plug is rated at 7 amps.
Q: is 18 gauge wire sufficient and is there some grommet available to install a new cord appropriately?
Q: can the original plastic grommet be removed without destroying it.
- the black wire of a Green/white and black wire twisted pair coming from one of the channels of the Loudness pot appears to have been cut off and not sure where it needs to be tied to.
Q: thought?
Just beginning the project so much more to follow. Thanks for the help in advance.
Q: thought?
