Moving Ahead
Well-Known Member
Is this the first time hooking up speakers? Did you have no hum before?
try this.
1/ reverse polarity on power lead. ie: unplug turn 180 deg and plug back in. any change? replaced x cap?
2/ get another amp and use the in/out feature. sherwood out /other amp in. lets eliminate the preamp and power supply.
3/ check polarity of your new caps. refer to pictures of the old caps that you've taken.
4/ check your trimpots. Sherwood of this age are flaky.
5/ check your ground connections. The points directly soldered to chassis can age and crack.- there are 3 ground points per main amp cards. re flow solder
6/ can you change main amp card from left to right and right to left? to determine the fault is on that card.
thats a start.
try this.
thats a start.
