Normal Steg
Hey there Audiophiles and Tech Wizards. I am reaching out to this community for some advice. I am a novice at repairing electronics. I can disassemble a device, deox pots, and I think I can even spot bad caps. I have repaired some really basic things, (recapped a pair of JBL L-100s, changed the power cap on an old tube radio), and I can do some basic soldering. My question is, should I attempt to fix the fuzzy left channel on my Sansui AU-7900, or should I take it to a pro to fix it. My issue is I have no one in my town that fixes vintage gear, so I have to travel at least 45 minutes to get to someone that can. Then, I have to wait at least a month to get my gear back. Is this a repair I can do on my own? Will I ruin my prized amp? Here are the symptoms and my troubleshooting.
Thanks,
Eric in Normal, IL.
- When you turn on the amp, there is a fuzzy sound coming from the left channel.
- The sound does not change regardless of what device is plugged in, what the volume is, or what input is selected
- The only thing that even remotely changes the sound is when I adjust the tone and filter selector on the bottom row of switches. (4ths from the left)
Thanks,
Eric in Normal, IL.
