kcblair
Back to records
Yep, but 0.25gr has seemed to work for me, if I need to fine tune , I just line up the little dial on the tonearm weight and go from there. The dial on my main TT is in 0.1 gr. increments . I really don't see a need for 0.001gr. on any carts. The one seminole54 suggested, I'm going to try, heck it's only $13.THat plastic AR scale works good, and its very flexible if you need to set up some record shredders. The only problem is the stock weights only get you to 0.25g increments, though nothing says you can't sub your own weights. Small washers and such will do just as well as the original plastic discs.
