flavio81
Turntable technician
This post is dedicated to @cafe latte and @Pio1980 who constantly try to improve their system by tweaking.
Yesterday i dusted off my PL-41 turntable with SME 3009 II non-improved tonearm.
Well, i fitted the Grado Red1 (actually a Grado Signature XTZ with a Grado Red1 stylus), and i was getting some sibilance on records that normally played fine...
Thinking that the stylus was perhaps a bit worn, i swapped with a Grado Gold3 stylus, completely brand new, yet i had the same problem.
Thus I swapped for an "easier" cartridge: I got hold of a my AT VM510CB mounted on an Audio-Technica LH11H headshell, a premium, very nice headshell.
Well, the problem was still there. For example I tried "Hall and Oates: Rock and Soul Volume I", and most tracks had sibilance. Other records had the problem so I immediately thought something was wrong, wrong. This time i coudln't fault the stylus, there are no more than 50 hours on that sytlus. Tried more VTF, tried realigning overhang. The problem was still there.
I recalled Alex Korf's great tonearm vibration analysis and how decoupling the counterweight can be of benefit. And the SME 3009 II originally has two rubber "elastic couplings" to decouple the counterweight assembly:
However on my tonearm it was replaced with the aftermarked teflon coupling (see example picture, below):
This teflon coupling is much stiffer than the original rubber coupling.
I am using the vtf adjuster outrigger, so the combined counterweight is in its heaviest configuration. Thus I thought that the energy from the stylus was exciting the tonearm resonances and causing mistracking.
The first thing I did was to try creating a makeshift spacer using a ca. 1mm thick foam sheet between the cartridge and tonearm, and then screwing the cartridge very gingerly into the headshell, so it is supported by the foam sheet itself, "floating" thanks to its compliance.
In doing this i was making a makeshift cartridge isolator, similar to "The Cartridge Man's Isolator" (sample pic below)
Or to Joseph Grado's tonearm decoupler:
The idea is to prevent the high energy of the sibilants to excite the tonearm resonances. Joseph Grado, who did know about tonearms (he wrote a nice article on tonearm design), put this in the instruction manual for the Signature series:
Well, back to the experiment with my makeshift decoupler:
Now the first, 2nd and 3rd tracks of the Hall&Oates record were tracked almost cleanly. Then I tried other records that were challenging (specifically, i tried records with choirs / background singers at the inner grooves -- and settled on "Vai Passar", Chico buarque, last track, at the inner grooves. Listen to it.). The problem was still there, but significantly diminished. Now it was only present at the inner grooves on challenging tracks, and now it wasn't exactly heard as sibilance, but rather what sounded like high harmonic distortion on vocals. A form of mistracking, i guess. This problem was also present before using the foam sheet on the headshell. The sound would be acceptable to some people, but to me it was evident that it was a problem.
Note that the VM510CB cartridge has a conical stylus so we're stretching the frontiers of conical tracking here...
So, first message to my friends: this thing (cartridge isolation) works. I am a witness.
NEXT STEP
Now, I theorized that SME engineers know much more about counterweight isolation than me, and fortunately i had the original, new, rubber "elastic coupling" ready for installation. I mean, these little grommets:
Thus, i removed the teflon coupling and installed the elastic couplers following the SME service manual. Now my SME was restored to factory spec.
I set the cartridge at 2.0g VTF as per the specs and...
Massive improvement!! Now even the inner grooves appeared to sound good. Even tightening the cartridge on the headshell (thus coupling it more to the headshell) the performance was good. "Private Eyes" (track), near the inner grooves, is rendered as good as I've heard with any other conical on my other turntables. The "Vai passar" track had much less of the harmonic distortion. It sounded clean at the female chorus near the end of the record (90mm radius --distance from the spindle) and good (okay) at the final chorus at the last grooves (70mm radius). Considering that this is not a brand-new record, and I have used it with various cartridges and tracking forces, this is sounding as expected for a conical stylus and i've no doubt that if I fit a microLine again, it would track cleanly.
And on the rest of the record, completely clean tracking. The VM510CB conical is a fantastic value for the money, and I say this as somebody who also had the VM540ML to compare with.
So, bottom line -- don't mess with the counterweight decoupling on these tonearms, i guess!!
NEXT STEP
![tonearm_longer_wand[1].jpg tonearm_longer_wand[1].jpg](/forums/data/attachments/3110/3110084-800f36855702a435c9606d9bb4f67a45.jpg?hash=gA82hVcCpD)
