Well the manufacturer wouldn't have done it if they wanted to make a cheap amp, some people can't afford expensive hifi which is why we have different tiers of hifi. Moreover, there are plenty of members on here who have bought cheaper hifi and have asked questions pertaining to improving it.In a word, no. Otherwise the manufacturer would have done it.
TBH, there are very few cheap, poor sounding amps, at least among those that AK members would be considering.
No, I've recapped it and it is fine, it sounded pretty good originally bar the volume knob problem.Is this the amp you're referring to
Integrated Amp Volume
Hi, I have a QED A230 integrated amp. When it's connected to my Rotel RCD-965BX cd player, it's very loud when the volume knob is turned very slightly. There's no way I'd have it turned up a quarter as I'd be scared my speakers would blow! I've tried running my streamer through it and it's...www.audiokarma.org
Solid state, all I was wondering was, is it do-able.Solid state or tube?
I should have elaborated on my question I suppose or posed it in a different way.Well, you didn't specify what "breaking the bank" or "major components" means. And there's a difference between "improving" vs. going from poor sounding to "pretty decent". But I maintain that if you found a poor sounding amp, assuming it wasn't due to failing./aging components, nothing short of a redesign is going to make it sound decent. For example, swapping out capacitors is not going to make a dramatic difference. Subtle, sure, that's possible.
There is plenty of gear of humble origins with the right combinations of speakers amps and surroundings will surprise you ! Low end junk is junk but there is plenty of mid level gear that can sound very pleasing under the right circumstances !I should have elaborated on my question I suppose or posed it in a different way.
Maybe I should have asked, What is it, internally, that makes an amp sound "good", and, could you take a poor performing amp and make it sound better than it does?
Hi, is it possible to take a cheap, poor sounding amp and make it sound pretty decent without changing any major components and without breaking the bank?
It's just a question that popped into my head![]()
You could do a few simpile things, as knotscott suggested, or you could redesign the circut, change transistors, transformers etc. Likely more cost effective to buy a better amp.Solid state, all I was wondering was, is it do-able.
