Yes, it is the 4Pi crossover, but with nicer crossover parts.
I figure that I might have to change out the resistors if anything, so I will temporarily fasten them in place, and the whole crossover is removable with 3 machine screws.
Didn't think of that... the .47 is epoxied down!
With such nice crossovers components, why skimp on the internal wiring and use such a high gauge? Or is it better than it looks?
As usual nice pics!
How's it soldering to the foil inductors? Plus, I guess it's okay to "uncoil" an inductor like the one in the upper right corne(of the pic)r as long as not to much wire is unfurled????
Have fun!!!!!
If further fiddling with the crossovers is in the plan, you might consider the solution worked out years ago on the KLH model Twelve. Bring out the leads of the individual drivers to the exterior back surface to screw connections and put the crossovers themselves in a chassis with outputs to the aforementioned screws. You can tweek for years without needing to open the cabinets again. Just a thought...
Cheers!
