Smart Phone Ohms ?
timofred
I'm just a garbage man...
I have seen headphones vary a lot,
32 all the way to 600 Ohms.
What is the most / least a smart phone can handle ?
My phone is an Oppo A77.
Cheers, Timo.
Without having done any laboratory testing, nor listening to a lot of different products, but a little reading on the ol' interwebs coupled with a little experience of my own... to me it seems when you go above 32ish ohms is where you start to see a headphone's performance start to fade, especially in bass impact. This, of course, may also be product dependent. This is referring to full-size, over-ear headphones.
LG smartphones like the V20, V30, V40, V50, G7, G8, and Q7 have a 32-bit DAC with a high impedance mode. If it senses headphones at 55ohms or higher it increases the gain. The phone says you can go all the way up to 600 ohm but I think 250ohm is a satisfactory enough ceiling for most headphones.
Thanks for the replies,
So far, every pair of headphones I've tried have sounded fine, never needing full volume,
You have put my mind at ease.
I have Monoprice 8323 - 40 ohms - for portable use with Note 8 - I needed to add a Fiio A3 to give them some oomph! Not more volume, but more bass and mid clarity and punch.
