Taketheflame
Ok, I'm back with a very belated update - well, not as much of an update as another failed attempt and some new questions.
Finally got around to trying to remove the dashpot cover again - unfortunately, it is on there very tight! Someone may have glued or sealed it at some point - no amount of applied heat, or force with rocking the jacket back and forth made it even budge. Anything more aggressive than I tried will definitely result in damage of a near-mint cover/the arm, so I backed off for now.
As some additional evidence it may have been messed with at some point, the arm's descent starts fast, slows down to a very nice and smooth, slow speed, then makes one faster drop at the end of the descent - as if there are air bubbles trapped in the system.
Some reading around suggests that people seem to have an easier time with removing the dashpot cover on the Improved versions of these arms, often with little resistance. I've also read that SME made a tool for removing the covers without damage.
What are the chances of finding one those tools? I know I will damage something taking any more aggressive measures, so for me it's probably a case of find the tool, swap for a later dashpot assembly, or damage parts to get the job done...
