So Cal AudioFest?
I agree, Saturday is better but ten days ago they had 4 dates available in April or May. All Sundays. If we do this again, I need to get further ahead of it.
- Pete
I'm game but even a small event has the same issue, where to hold it.
I'm thinking October. Anyone have a preference for the date?
- Pete
Any Saturday this far out should be good. Maybe we should meet to plan the event. How ‘bout Joe Jost’s in LB? We could meet every week until we get it right :biggrin:
Venue, venue, venue! How do the other AKfest’s do it? I think they have it at members’ homes. Two of our three were at homes. @birdwire hosted in his garage, @David_NC hosted in his house and @HBTim and I have hosted a small listening party. @toddalin made an attempt to host as well. Perhaps regular small gatherings would build greater interest, and grow into something larger?
People need to hear the latest iteration of the Mermans. These have got to be the imaging champs of all time!
Since our last meet, we've acquired a couple rescue dogs and the cattle dog (a red heeler) really does go for the heels! If I try to walk along with someone, she will "herd" them as one of my beasts nipping at the heels. We walk four times a day for 2 hours plus.
I love rescue dogs, every dog I’ve ever had was a rescue. The pup we adopted about a year ago was a mixed breed, but mostly a Aussie stumpy tail cattle dog. She’s definitely had the heeler characteristics as she always went for ours! She doesn’t do it as much now as we give her tasks and play with frisbee and balls which she loves doing.
Our cattle dog, actually 3/4 Aussie red heeler, 3/32 Husky, 3/32 Malamute, 1/32 German Shepard, and 1/32 Rottweiler, has virtually no tail, so she had an original owner. She came from the Bakersfield area and that is a dumping ground for these dogs. Our other rescue is 7/8 Formosan Mountain Dog and 1/8 American Pit Bull Terrier.
For the Large Scale Online annual build challenge, this years' challenge is to build something "whimsical." My entry is shown here. Voting starts next week.
EMBARK DOG PARK
The EMBARK DOG PARK was constructed to compete in the 2026, Large Scale Central build challenge. The challenge is an annual event with a different theme each year. This year’s theme was to build something “whimsical.”
I’d competed in several past challenges and my builds are known for their automation as well as their “off the wall” sense of humor. This year’s challenge fit right in. So where to start?
In the past few years, we had taken in a couple rescue dogs and these now take most of my time and attention. In addition to the garden railroad, one of my other passions is vintage Corvettes. So why not “merge” dogs and cars and what would that "yield?"
One takes their dog to the “dog park” expecting a park-like setting with trees and grass to play on. But when one takes their car to the “auto park” they expect something quite different, such as parking spaces and even a parking structure. So…, what if:
The plan was to have two dogs circle a fire hydrant; one peeing (yellow-colored fishing line) while the other is “scratching” his butt. Additionally, two dogs were to tussle over a bone and I wanted the railcar itself to have some animation. Other dogs would be “parked” like cars, both in lined spaces and, less formally, in the “parking structure.” The railcar itself was to resemble a dog walking along the tracks and a structure would be necessary to conceal the workings.
The model is based on an LGB 2065 European diesel that has had the body removed leaving only the chassis, motor, electronics, and lead weights. The weights serve double duty as heat sinks and these needed to remain leaving a “channel” down the center of the car. All animation toward the front would have to run through this channel.
Two 9.8-inch long, perforated circuit boards glued together serve as the basis for the build allowing me to very accurately locate the various components, screws, wires, etc. Plus, the holes are all predrilled, at least as starters. A 2-foot piece of railroad track was stripped of its ties and the two rails were shortened and glued to the outer edges of the board to provide support and stiffness.
The area for animation was determined and double-sided Scotch tape applied to the surface. A thermal-laminating pouch was opened and the “glue side” painted with watercolor paints. These did not stick/brush well, and the sheet was later given a light coat of green spray paint to obscure the clear. This was applied to the tape surface and pressed into place. But ultimately, there were a few wrinkles even though any trapped air would expel through the PC board. A Teflon-coated “Monocote” iron (used to put the skin on model airplane wings), came to the rescue and I was able to iron the entire surface totally flat “energizing” the glue on the thermal laminating paper. For the dogs to move unimpeded, the surface has to be very smooth and clean. Even an errant spot of glue will throw off the animation. Using Crafters Goop in these areas, rather than CA, I was able to simply peel away any excess encountered. All other areas were to be covered in brick. I think the end result came out better than expected.
Three slow motion motors power the animation. The two dogs circling the hydrant are moved by rotating magnets under the circuit board with magnets glued to the dogs’ feet. The motor is located in the shed and a belt runs the length of the car turning a pully with the magnetic assembly attached. This, and all other pulleys, were 3D printed.
Similarly, the two dogs tussling over the bone use a slow-motion motor, but in this case the “pulley” converts the rotary motion to a linear motion and magnets under the deck pull the dogs’ feet, also with magnets, back and forth.
Finally, the tail is moved by the third motor causing the “stem” of the tail to oscillate back and forth as the “pulley” circulates. If a picture is worth a thousand words, a video is worth a million.
The body, “nose” and hind quarters were 3D printed from ASA filament. This is the most resistant filament, is not-biodegradable, and has an unlimited life span. The body was obtained as free on-line clip art (jpg) converted to stl format though a free on-line program that will basically converts most any image format to any other format:
Convert Image to STL format online - AnyConv
Using Paint, I first split the jpg image into the head, hind, and body sections knowing that I was going to have to stretch out the body. I then converted each of the three pieces from jpg to stl format and used the 3D printer’s (Bambu X1C) software to stretch out the body while keeping the height and depth as is. The three pieces were glued together and brass channel was added along the inside of each side allowing me to attach the sides to the circuit boards/rails while providing support for the 2-millimeter ASA sides of the railcar. Detail was done up in CAD, colored, and added to the body. The headlight was contributed by a Bachmann tender. The tail is 0.006-inch-thick brass sheet cut out with a scissors. The “tongue” was also a converted clip art image printed very thin (0.6 millimeters). The piece was then colored and bent to shape by laying it over a jar and heating it with a blow drier while “working” it with the back of an X-acto blade. The boards/sides/nose/tail assembly was then attached to the LGB chassis using double sided foam adhesive tape placed atop the lead heatsinks.
The railcar is currently occupied by 19 dogs and five people. People come to park their dog for the day while mulling about town or just going about their business. Some opt for the longer-term or overnight covered parking in the structure. We are a full-service facility, factory trained in servicing Mack Bulldog equipment, and carry the right Purina Chow to fuel even the most fussy of rides.
Here's our pup less than a week after we adopted her. What a cutie, and smart as a whip too! Because of her breed's genetics, an inch or two of tail is all she's naturally got as you can't see LOL! I had to keep a close eye on her as a pup as there are plenty of dog snatchers around these parts.
Here's our pup less than a week after we adopted her. What a cutie, and smart as a whip too! An inch or two of tail is all she's got as you can't see LOL!. I had to keep a close eye on her as a pup as there are plenty of dog snatchers around these parts.
Like I said, Paya's got no tail. In fact, her fur pattern down her lower back is like an inverse ridgeback going down into the fur rather than rising above it. I've never seen another like it.
Dani has the most beautiful tail that curls all the way around like a cinnamon bun. She will wrap it around my arm and hug me with it. Paya hugs me my leaning her butt on me. The two dogs are total opposites in their personalities and everything they do..., including how they potty.
This thread has really gone to the dogs. :rflmao:
I'm always up for Joe Jost's. I'm meeting guys there for lunch today. I'll meet you there almost any time.
- Pete
I’d be interested in attending one - large or small. I’m in the high desert now (Joshua Tree), so I can’t help with hosting in the more coastal counties.
I see people mentioning actual venues; is nobody willing or able to host at a home?
I can’t recall how many we had in Santa Ana on ‘20 just before Covid, but there had to have been at least 25-30 throughout the day. That seems to be a manageable size, especially if there are multiple areas for different systems and activities.
I’m not sure if any on this thread are in the desert areas, but surely we have some members in the Palm Springs / Coachella Valley region that might be interested in doing something out here. My place here isn’t as big as the house in OC, but we can certainly expand outside. Music outdoors is always enjoyable!
Its July 2nd today.
I know this because Taylor S gets married in MSG tomorrow, the day before the4th of July.
Has this taken place yet ?
ee
Its July 2nd today.
ee
Sheridan Taylor getting married. I didn't know he was single.
It's time to start planing this event for the fall. I'm thinking early October. Does anyone have a date preference?
- Pete
My house would be too small for the event, but my garage would have worked great...if I hadn't filled it up with so much junk LOL! I'll have to clear it out sometime...
BTW, I was recently in your neck of the woods for my granddaughter's HS graduation, she lives in Twentynine Palms.
