Yes, without doubt. OK, decision made!Hasn't everything you've said favored the 1200?
Electrocompaniet/Sonus Faber. If anything I was worried the Denon might be a bit too budget.....Depending upon the type of music you listen to and the rest of of your setup.
There are less expensive options to the Denon DL-160.
Budget is 700€ music taste is broad but contains a fair swag of classical, German rock and fado.I find the DL-160 to be a very nice cart.
As for the Rega P3 and Technics SL-1200, both have their strengths and weaknesses.
Good thing though is both sport a strong cottage industry for modifications and can be brought up quite a few levels in performance- all at once, or over time, and in smaller cash outlay increments.
Can you elaborate on your budget and listening habits?
Don't think Music Hall or Sota are readily available here, being Germany/France, and Clearaudio is way over budget.
Had Pro-Ject before and would never consider again unless they've fixed the noise problem.
Music Hall isn't available here to my knowledge.
Not really - the more I think about it the more I think the Technics would be a good choice. The thing holding me is whether it would go well with the rest of my gear, which is an Electrocompaniet Class A amp and SF Minimas/Concertos.
I think it does come down to a bit more than just Rega vs. Sl-1200 in way, though those are the only names that have been bandied about for the most part.Technics SL-1200 all the way. It will compete with and beat any turntable under $3000. They just plain have better specifications. It's like comparing the specs of a Technics receiver to a fancy tube amp, the Technics will win on paper every time.
The only reasons Rega's sell well is the snob appeal and fancy marketing, Roy Gandy doesn't know the first thing about designing a good sounding TT.
As an aside: Technics receiver vs. good tube gear? Yeah, the Technics wins on paper. Apart from that it ain't no contest. I own both and you're talking about two massively different classes of SQ, specs or no specs.
All I can say is read the sig.:scratch2:
The reason so many people recommend Regas are because Rega P3s sound better than a Tecnics SL-1200. The real weakness in the SL-1200 is the tonearm.
