Blue Shadow
Waiting for Vintage Gear from this century
this endless discussion on re-capping
AK at it's core
Because it is a hobby and we can.
Enjoy the music while engaging in that activity.
You used the word "scare" three times, so perhaps this is an activity you should not be pursuing. However, keep in mind that the idea of changing a speaker's sound can have at least two outcomes: degrade the sound or improve the sound, to name two possibilities. The only way you are going to be able to make this assessment yourself is to try the re-cap and then form your own subjective conclusions. If you read too much of this endless discussion on re-capping, you'll hear dozens of different thoughts. Have some fun with this hobby, reduce the anxiety, and create your own opinions.
In my book, if you need to “fix” a speaker, then why not find something more suited to begin with?
Repairing an old speaker with tired NPE using newer NPE isn't redesigning but renewing and you should get back closer to the manufacturers product offering when new. But who knows, replacing the surrounds are probably changing the sound a bit, too.
Thanks, ra.ra
Guess what I’m trying to say, is that I’m of the thought that I want to hear the speaker the way it was designed and intended. In my book, if you need to “fix” a speaker, then why not find something more suited to begin with?
For a little backstory, I have recapped a pair of Realistic Optimus 1000s (similar to the Mach series, they’re a 15” 3-way from the late ‘80s). They still sounded great, but after reading a bit here about how NPEs are “crap” and should be replaced due to age (regardless of sound), I dove in. First set I used were also NPEs, because I didn’t want to brighten them as poly and film caps tend to due. However, I found that even the Parts Express NPEs were very bright compared to the Mundorf E-Caps that I eventually settled on. The Optimus 1000s were originally a very warm speaker, and I didn’t want to change that character.
So you can see what I’m saying here, that changing caps (even to ones of the same type, but a different manufacturer) can drastically alter the sound of a speaker. Some guys like that, and that’s their mission. I’m not one of those guys, I like to hear the speaker the way it was originally intended. To each his own, I guess.
Thanks,
Joe
P.S.- You mentioned that caps can degrade or improve the sound. That, in and of itself, is another issue. Some guys’ idea of improvement may be vastly different from another’s. Most here seem to like bright speakers, I like mine warm and lush. So that’s another issue with the “these caps are the best” theories, how to define “improvement”...
Poly caps certainly sound better than NPEs. Usually, clearer, cleaner, with greater resolution. As a result, that can make speakers sound brighter, after the recap. But, to me, you're finally actually hearing what the speakers are capable of...
...I'd try ClarityCaps. They definitely sound warmer in tonal balance than other brands that I've tried. Another reason that Claritys sound a bit warmer, is the fact that their ESR doesn't measure as low as other poly caps. Their ESR is pretty close to a NPE.
The next two, DCM CX-17 and NHT SuperOnes (original), only the caps were replaced using Dayton's (can't remember what tolerance) and I wasn't impressed with either. Like the OP, they bothered my ears. The DCM's were given away, and I can't see spending more money on the NHT's to recap them again. They too will probably be given away, or sold at some point.
The last is a pair of Totem Sttaf's. The only reason I recapped them is because they bothered my tinnitus (as do many other speakers). Recapped them with Sonicaps and couldn't tell any difference, sound wise, but they still bothered my tinnitus. (Gonna put the originals back in at some point.)
The ClarityCaps took several weeks to smooth out, playing 3 to 4 hours a day. But, they were the exact opposite of the Solens. Instead of too peaky, they were too muted. No upper mid air or clarity. That partially went away with burn in. The addition of the bypass cap smoothed them out even more, and brought out detail without adding harshness.
Interesting and my findings too. I replaced 3.3 mfd Aerovox caps with ClarityCaps of the same value for the Heil and found the highs were muted compared to the Aerovox, which were a bit too bright. But, I did add 1 ohm to the Heil when changing to the ClarityCaps, so this is not exactly "apples to apples." BTW, the ClarityCap values were all right on the money, as if they were hand matched.
I then added a 0.1 mfd styrene cap to the 3.3 mfd as a by-pass (3.4 mfd total), and to let the Heil go a hair lower, reducing a slight dip in the crossover region, but didn't note any real difference. Eventually, the highs "came around"... or I just got used to them.
I'd never read that so I took a look. He says "In a nut-shell: microphony is the keyword - the mechanical resonance, a key feature of audio capacitors. This is a physical deformation of the capacitor plates which occurs as a result of the audio signal passing through the component..."I don't know if you've ever read Tony Gee's capacitor tests, ...
Well I have to totally disagree with his assessment of Erse Pulse X caps. I have them on a second pair of ESS AMT3 Heils, in the tweeter mid circuit, and the are totally natural sounding, with a great soundstage. Zero micro phonics. Typical Great Heil sound at it's best.
I take those type of reports with a grain of salt.
I bet in a double blind test, he would have little clue which caps where which.
I saw such a test awhile back, and so called golden ears could not tell the difference between a electrolytic cap, and a poly cap, let alone brands.....
IMHO if a cap is made to sound a certain way, it's not doing it job anyway...
But hey, if you think you really hear a difference between properly functioning in spec caps..be my guest!!
I used to have people sweating it out on some of my AMT3's threads-types of caps, etc. Just remember how well those speakers sounded new with $2.00, in spec (hopefully!) caps....
Speakers don't sound "well," they can sound anywhere from terrible to great but not "well."Well I have to totally disagree with his assessment of Erse Pulse X caps. I have them on a second pair of ESS AMT3 Heils, in the tweeter mid circuit, and the are totally natural sounding, with a great soundstage. Zero micro phonics. Typical Great Heil sound at it's best.
Myself, and a number of other audio file buddies couldn’t tell the difference between the two.
