VintageDutch
Hi all.. >>>>Hold on, sit tight, don't hold your breath.... This is gonna be a longggggggg read.>>>>
Got my Second SONY in beginning of April 2021.
Bought it for € 85,-- ex shipment (€30,--) from Germany to the Netherlands. Never heard it play... and I did not touch it.. It was from a Guy who I dealed with before and we have a trust relation on the Vintage HIFI gear...
He tells me what His findings are and ships and waits for me to pay on arrival...
On arrival....
After cleaning the fascia
From the sellers pictures I was prepared for some Nicotine. But this one had it really caked Nicotine and other filth on and in it...
During shipment sadly the power switch got a hit and did not survive.
I Hot wired it and ordered a original NOS ALPS switch from a Japanese supplier I found in a Treat on another forum.
After the hot wiring I was able to get FM reception on it on my Headphones and already I was stunned by the sound...(just on headphone!!)
I cleaned the switches, and replaced the Light bulbs (nearly all were dead) and It started to come alive...
Sadly the all but 1 VU Meters were all Stuck half way or at full scale. This did not vote to well for this meters..
Light bulbs replaced... see the VU meters "hanging" stuck.
This weekend, I got the Power switch in, so a good excuse to breakout that trusted Soldering iron.
The power switch was Quicky installed and all working fine.
After that I "attacked" the VU meters... So out came the tuning scale, exposing the vu meters "mounting"
I any one tried before these thing are stuck in there with double sided sticky tape from the 70ties... That stuff is hard... and could just as well be glued....
But nothing what a Little heat could not solve... and sure as anything... heating the black chassis steel up released the glue making it pliable again... and plop there it is...
Meters came out with no problem...
Marked and grouped the wires and simply cut them off.
Time to open up the Meters.... and this is what I found...
The VU meter scale is all bubbely...
No wonder the meters can not move...
After some fiddly stuff involving a Long "break of" type of Stanley knife between the Back side and the VU meter scale I was able to remove the scale carefully... Remember... these meter are very fragile..
Close up the VU scale looks like this
Clearly to see ... the scale is pretty warped... And I have a clue what has been going on....
The scale it self is glued with double sided sticky tape to the backside of the meter..
The regular light bulb heated the meter and the sticky tape.. The problem with that is that the tape after it got older It lost its flexibility and shrunk, but it was so hard stuck on that scale, scale actually did came a bit loose and "got pinched" by the tape resulting in bubbels..
SO basically we have a construction flaw...
I tried my luck on the good old interweb trying to find solutions, trying to find fitting replacements, I even fumbled around with a pair of AKAI tape deck meters I had laying around... No luck what so ever...
New Meters are just Way bigger so never will fit. there are no spares anymore... and no after market replacements.
SO... back to the drawing board.. first lets test the meters them self.. and I got very luck... all 4 are still moving after removal of the VU scale.!
Then the next question..... Do I feel lucky... Yes i did ..
SO I took a chance.... Pulled out the small blowtorch again.... and heated (from a distance) the scale a bit until I saw and feld It was a bit more pliable. I quickly put it down and cooled it with a piece of flat iron... Repeated thet proces on small sections... And it worked!
Both scales a now back nearly flat!
Left to do is cleaning those suckers up..... removing the last pieces of sticky tape...
The same on the meter body (in the pictures You can see them in the background) e try to bleach the VU meter body a bit)
Tomorrow get my some nice transparant glue and get it al together again.
I really think I got very very luck today, and that the Quadraphonic HIFI Restore Gods where on my side..
What I'm also gonna do is Wash that stinky Receiver from the inside with Aceton..... Man that thing still STINKS after nicotine.... Horrible..
Will be continued
On arrival....
Will be continued
