Chimpleton
Diodes changed, switches and pots cleaned. All systems are go!!!
Thanks for the help guys
Thanks Echowars.
Q1: My 1N4148 diodes came in a bag marked 200A, 100V DO-35. Maybe mislabled? I'm showing a photo below of two of them installed in the D303 position.
Q3: refers to having received this amp with one channel that has one 2SK60 of rank 54 and one of rank 56. The other channel is the same (a 54 and a 56). Wouldn't it make sense to swap them so that one channel has two rank 56 2SK60 devices and the other has two rank 54 2SK60 outputs? The first photo (first post) shows how they were installed when I received it. The second photo shows them switched having two rank 56 on the left and two rank 54 on the right. Do I need to be concerned about swapping them for any reason to this, seemingly, more logical matched configuration?
Thanks for the advice on the insulators. I have mica and grease. Will do.
Do you have a main filter cap replacement you could suggest? The original is 10,000uf 50v, 40mm diameter X 70mm L. I would guess you've replaced a few of these. Most newer ones of like value are smaller. Thanks again.
