Well, I would not argue with ilimzn, but the transistors that the diodes come in contact with (Q310 and Q360) are the pre-drivers, and even when running the amp hard, I don't measure but a few degrees temp rise over ambient. But I have always left the leads long enough that the diodes will heat up simply from the heat rising through the chimney from the main heatsink on the output devices.
But if we are going to discuss 'best practices', then heatsink compound and heatshrink is a good idea. I have not always religiously followed this method, since IMO the heat through the chimney allows for a Vf drop on the diodes about as much as any heating from the pre-driver.
Glenn, the diodes do not compensate for the changes in temperature of the output stage. VFETs have practically zero temperature coefficient, but the predrivers do not. This is not an issue of thermal runaway like on regular amps, just bias stability.
The predriver/driver setup is such that every mV difference across the predriver bases multiplies by about 33, so the difference in the bias this produces at first glance is not problematic given that the tempco of the semiconductors is ~2mV/degC. However the arrangement of the circuit penalizes lower VFET ranks - the lower the VFET rank, the lower the bias voltage is required for the same bias current. In this sort of driver setup, this also means that more bias voltage is required across the predriver bases, increasing the temperature dependency of the system (because the same drop across 3 diodes is just divided down by the bias pot, so is the temperature dependent part).
On the 5650 the issue is smaller because of the chimneys - airflow is well controlled so the internal temperature of the amp is less influenced by the heatsink and rises or falls slower, alowing the system to stabilize well. On the 4650 less so, no chimneys - hot air goes everywhere. Depending on how hard the amp is driven, the bias can go quite a bit higher once the lid is on, unlike the lid off condition when it is adjusted. Also, winter/summer temperatures may affect it. Taking into account all extremes, you can a nearly 4V change in bias voltage from extreme to extreme, which for rank 4 VFETs will almost double the bias current. Fortunately, since the predrivers and the diode are close and we are talking ambient temp, such a situation is virtually impossible (unless some idiot 'tech' uses something like cold spray on the predriver while the amp is working!!!) - BUT I have seen 100mA set up open become 125mA closed, with a temporary rise to about 135 since the predrivers also generate their own heat - until everything stabilizes. Depending on actual conditions, the 'hump' before stabilisation may be larger on low rank VFETs, and sadly, with less and less being available to fix the amps, one may be faced with an option to use rank 3, 2, 1... (yes they can be used but provisions such as this have to be made, rank 2 and 1 must be checked on a tracer and selected, especially for the 4650). Now, it's not that VFETs are extremely sensitive to the bias current tolerance, but it can be a nuisance, and a bit of thermal goop and heat shrink solve that.
