EDIT: Also, please check out your wiring to the middle switch (S608).The third photo shows wires to that center switch. The green and yellow go to the front pin and the orange wire goes to the back pin. ???
OK. I watched another video and what it looks like is that when you press STOP, the two tension arms retract into the silver housing that you see in the photo from the internet above. When you press FWD or REV Play, that little tension arm comes out of its little house and presses against the outside of the tape (as shown in the internet photo above). As soon as you press STOP again, that tension arm retracts into its house.The tape is on the outside of the tension arms. I cant do that with the front plate on but didnt notice with it off.
Where is Q604, I don't see it on the schematic or board layouts? Did you really mean Q704???I measured Q604 and got nothing.
