Soundcraftsmen PM860 / PCR800 power-amp restoration
Racingh11
I bought this amp in rough shape as a project to match my other PM860 beater amp. I should have taken before pictures. The inside was coated in heavy dust that was also oily. And all of the black sheet metal parts had the paint pealing off. I opted to fully disassemble the amp. Ultrasonic cleaned everything and stripped the metal parts down and repainted. I installed a handle and additional rubber feet to match the other PM860 I have. Makes them real handy for mobile use.
I replaced all electrolytic capacitors and all small signal TO92 transistors throughout. I also installed one of my own input boards that makes it bridgeable and switchable low-pass filter with bass boost for a subwoofer, and a turn-on muting delay. It also got gold RCA inputs to replace the 1/4" phone plugs
After everything was assembled and settings were all adjusted, it was tested on the distortion analyzer. It seemed fine until I approached high power and distortion rose before the rated power. After connecting the oscilloscope to the high voltage transformer connection to the power board, I could see it was only charging the caps on every other phase. I traced this back to a bad solder joint at a diode used to sense that phase. This is why the previous owner installed a 15A fuse instead of the 10A stock. Because these amps have to charge at twice the amperage when it happens half as often, and they blow the fuse. It now has a maximum of .0113% THD at 205W 8 ohm. I also tried bridging to 8 ohm, tests .006% THD up to the 300W my loads could handle. IMD is even lower at .0033%.
Another thing I did on this amp was install a C13 power cord socket. This makes it much easier to work on and gives cord options. This is the second time I have installed a heavier awg power cord. Stock is only 18 awg. The last amp I tried had increased 1% THD clipping limit with a heavier cord. But I didn't test before to verify that was the reason. On this amp I was able to switch between a 10' 14 awg cord and a 6' 18 awg cord. I have 6' 14 awg ordered.
The 14 awg cord powered the 1%THD RMS clipping level all the way to 260W per channel 8 ohm, both driven at 1khz. The 18 awg cord brought it down to 220W per channel. (rated 205W) The cord alone was worth 40W per channel increase in RMS power!
Is the Soundcraftsmen/MTX S-860 the same as the old PM860 ?
Yes it is, that's why they have the 'S' in the model number, as in, Soundcraftsmen. They didn't change it like the other models. The other models MTX changed used 'A' in the model, such as A400, A200. I've had a few of the S860s through here.
I use one of these with a bridging board to power a 1000W RMS, 18 inch, 4 ohm subwoofer. Pushes 900W in that configuration. I also use a pair of these bridged to power a pair of dual 12 inch PA towers. Each tower getting 900W. They really slam, and from such a compact size. These are only a half rack width.
How do you feel about the Hafler Mosfet vs Soundcraftmen Mosfet amps ?
I was offered a PCR-800 for very cheap, do you think the PCR-800 is better than a Hafler dh-220 for home audio ?
I definitely like the Soundcraftsmen better. Today, someone brought me a DH220 with a dead channel for the second time in a couple of years. It's a frat house amp and takes some abuse. I'm convincing him to buy a nice RA5504 to replace it. It's about the same wattage, but a very durable and serviceable design.
An amp that doesn't work, doesn't sound like much at all. I would prefer to keep this thread about restorations on the PCR amps and not interested in discussing what things supposedly sound better than the other.
It turns out, the problem with the hafler 220 was the RCA inputs this time. The insulators were chipping apart and the cable lost contact. I replaced them with the same gold RCA jacks that I put in the PM860. I retested bias, offset, and distortion while it was here. All good. It idles close to the same line power as the PM860 at around 35 watts. I had previously repaired a channel in the 220 by installing used MOSFETs from Soundcraftsmen amps such as this one. It also got the same power caps. The Hafler typically uses a lot more idle power, but I adjusted it to lowest distortion. It can be read about in this thread.
https://audiokarma.org/forums/index...h-220-warm-because-running-in-class-a.859644/
A cool project!
I've never heard of one before but I have to admit the first thing I thought when I saw the photo with the handle was it being handcuffed to Elwood Blues. "We're on a mission from God..."
A cool project!
Thanks. I don't know that reference, but I'm going to look it up.
I'm expanding this thread to include the PCR800. I started on one today. It is from 1984, the first year for the model. It was crusty and dusty. I vacuumed out some grasshoppers. It has one SCR and a resistor burned that I can see. It will get all new caps, some transistors, and paint like the PM860. I have the original box for this one too.
IMG_1274.JPGIMG_1276.JPGIMG_1278.JPGIMG_1279.JPGIMG_1280.JPGIMG_1281.JPGIMG_1283.JPGIMG_1286.JPG
