I'm not sure I can believe all the things he states that they will do for a given piece of equipment or system.
If all those claims were true, maybe. But the claims kind of read like hyperbole.
I get wanting a stiff well filtered power supply for hifi, but does it have to use such expensive componants? I would think going SS would be much cheaper.
Out of all my tube amps and preamps, only two amplifiers and one preamp use a tube rectifier. I don't want voltage sag in my hifi equipment.
OK . . . but how many people with lower budget tube gear are going to be spending that kind of money on a power supply? I would think they would be much more likely to just put the money into a more expensive - and hopefully better - amp.This could conceivably increase the performance of a lot of lower budget tube equipment.
Yes, I agree, but that wasn't the question. ;-) The question was, why are they so expensive? My point is, whether they work or not, they clearly don't look cheap to build. I'm sure the markup is considerable, but we're talking about a custom piece aimed at well-heeled audiophiles with a yearning for show-off tweaks. The fact that they're a little off-beat is probably a plus. ;-)
The problem I have with his inventory is that, if every piece is essentially a one-off, how can a potential buyer know he or she is getting a consistent product? A Rogue amp is a Rogue amp. If a friend has one and you like it, you can buy the same thing. Here, you're just taking a stab at whatever he had on hand at the moment--or at least it looks that way. ;-)
These are for the same guys who don't mind spending $1000+ on a set of interconnects, or expensive linear power supplies for a DAC or streamer. This isn't about watts per dollar, it's about having a hobby centered around spending money on gadgets that nobody else has, and frankly I think it checks the boxes.
No, just no.Not much information, but curious as to any possible benefit for some equipment (I have no interest in buying one). Any thoughts?
http://www.thebestamp.com/Accessories/Super_Rectifiers.php
Some amps may have issues with voltage sag and I don't doubt that these units would alleviate the problem if it exists.
SE amps, which are Class A by definition, and PP amps that are designed to run in Class A have very little variation in current draw and, as a result, rectifier sag would typically not be a problem, or at least not a serious problem.
