I fixed it by ordering the foam, getting aleenes tacky glue from my local craft store, and set the woofer on a stand where the cone is facing the ceiling. I brushed the glue onto the very edges of the cone, and on the (apologies as I don’t know what it’s called) outer metal holder. Then I carefully placed the foam onto it so it has the edges of the foam in contact with both the cone and the metal holder. It’s very important to keep the cone centered, as you don’t want voice coil rub. It sounds more difficult than it actually is. But I must say, I sort of agree with the others to have it looked at by someone who is experienced. I may have gotten lucky with my first refoam, id hate for you to have poor results.That was actually my reply to Madeline, when she said she fixed it.
Question: Is the broken down foam what's causing the rattling sound or is it something else?
It’s very likely. Could be something else, but either way you will need to refoam.
OP should ensure that the repair shop is wiling to repair the woofers and not just replace them. How many times have we on AK seen speakers that were supposedly "professionally repaired" just had the woofers replaced with some cheap generics?I suspect it would be in your best interests to look up "speaker repair" in your local area and pick a professional to take over.
Agreed.OP should ensure that the repair shop is wiling to repair the woofers and not just replace them. How many times have we on AK seen speakers that were supposedly "professionally repaired" just had the woofers replaced with some cheap generics?
You can unscrew the woofers and look at the back for identification possibly. If you get them repaired, check and see if it’s the same woofer by the same process. Or just visually see them and make sure they look the same. Any other input on this question from others?Yeah, I'm online now looking for repair joints, and will seek out reviews, check the BBB, local Consumer Affairs office, etc.
And how would I know if the woofers were actually repaired or replaced with junk?
I use an engraving pen to mark most of my valuable items.You can unscrew the woofers and look at the back for identification possibly. If you get them repaired, check and see if it’s the same woofer by the same process. Or just visually see them and make sure they look the same. Any other input on this question from others?
Does Human sell refurbished woofers with a trade-in? I know they do for the inverted dome tweeters but any refoaming I need gets done by me so I haven't had a reason to find out.
An underlying issue? Half the speakers have turned to dust! What could be more serious than that?Not sure I'll center it correctly, and don't even know if there is another, underlying issue going on with them (hope not).
