We have to be wary of confusing effects in light of differing objectives. For those who worship at the altar of detail and imaging, stacked speakers are anathema. They would probably be best served by a room with very little acoustic reflection, two speakers in the space, and sitting in the perfect spot.
That's great, if that's the objective. I don't listen quite that way, though. My objectives, which certainly don't need to be anyone else's, are tonal accuracy (as opposed to detail), and realistic dynamics. Realistic dynamics are the most difficult to achieve, but I think make a bigger difference on the listening experience than detail and imaging.
I've done some REW analysis in my living room, where my main system resides. The response shapes I saw were absolutely jam-packed with comb effects playing the sound in all four speakers. I thought, "Rick, that pair of Advents is surely causing this vast array of comb effects your are seeing. Try again with just one pair." So, I turned off one of my amps and tested again. Very similar results--jam-packed with comb effects. "Rick, you are playing the same signal into both speakers of the stereo pair. Just do one channel at a time." Again, similar results.
Guess what? Reflections from the room interior cause more comb effects than pairs or double pairs of speakers. Who knew? So, I could line the walls with Sonex and make it look like a radio studio, though I'd better take a picture of it quickly before the divorce papers are served. Or, I could build a wall to close the room in from opening up to a loft area, so that I could put the speakers along the long wall and out into the space. Get that piano out of there! That vast soundboard adds its own sympathetic resonances. Cover up those windows opposite where the speakers would go! Don't you know glass is reflective?
The point so far: Comb effects are caused at least as much by room reflections as by multiple speakers.
Does it make me less of a purist that I choose to live in my house as the architect designed it? As the wife demands? As
I demand? Could be. Whatever. I have an imperfect space and that's just the way it is. A key problem in my space is that the floor along every wall is consumed by one thing or another. I have a grand piano at one end, comfy chairs with a map case that I use for art prints and my own large photos between them. Then, a case for CD's in the corner (acts as a bass trap--prove me wrong). An "open concept" opening into the den. A stereo desk that is actually a two-drawer lateral file cabinet full of music with my turntable on top of it. A matching shelf unit next to it where I put the rest of the equipment. The chair I sit in to play tuba, and all my tubas along the remaining bit of wall that is actually the side of a staircase going to the loft area and second floor of the house. Next to that is an opening into the entrance hall of the house. There's just no place to position speakers according to purist standards. So, I put them on a shelf mounted to the wall above the stereo equipment, far too close to the ceiling, especially on the left channel, and with too little separation. Just about everything is wrong with my speaker location, if detail and imaging is my goal.
(My neighbor down the hill built his house with a custom listening room, optimized and perfected. It's awesome. He does not equate listening to music with enjoying natural light and beauty as I can from my living room. And he also lives by himself.)
So, I turned everything back on and analyzed again, and set up my awesome Yamaha YDP2006 parametric equalizer. The result is reasonably linear up through about 15KHz, which is where the Advents start rolling off. No matter--my ears roll off lower than that. The comb effects are still there, but my listening position is 15 and 18 feet away from left and right channel speakers, respectively. Guess what? The Yamaha will apply a slight delay to the left channel so that it will arrive in correct phase alignment (for those frequencies low enough to matter) with the right channel. If that equalizer adds any mud to the sound, either I can't hear it or my Advents can't do any better anyway. But with it in place, the room sounds more controlled, and I hear more of the ambiance of the recording space (important with well-miked classical recordings, in my view).
But detail? Recorded piano sounds pretty close to the real piano in the room, differences in the instruments considering. Imaging? Well, not so much.
But for sheer dynamics, that's where the two pairs of Advents really shine. Each pair is driven by its own high-current B&K amplifier, in what I call a Dual Stereoblock (R) setup. There are not many affordable bookshelf-mounted speaker arrangements in my experience that can produce the same "slam". Four 10" woofers move a lot of air, and being part of an acoustic suspension design do so with discipline. Four tweeters heat up a lot less than two driven to the same SPL.
I think the point of the Grateful Dead wall of sound was visual as much as aural--the concertgoers have two speakers at home, and these guys had 200 of the same sorts of speakers (or at least they look that way). You hear what you see.
The pic is old--many equipment changes since then, and far better air management for cooling.
Rick "music practice is a messy business" Denney
