Thrill Kille
I've read in another forum a good argument against smaller (12, 10, 8) gauges of cable in most systems. Especially in those less than about $7,500 or so.
Anyhoo, It was brought up, and I had to agree. That a fellow 'Phile was going to use 14 or even 16 GA wire for DIY speaker cables. Saying that [...the audio engineers at McIntosh in their good wisdom chose that size wire for the internals of their tube amps...] He wasn't sure if it was 14, or 16 GA. But he was going to find out. Paraphrasing here.. That if it was good enough for inside of the amp. Then it should be good enough to run from the amp to speaker.
So, I looked under my own MC30. And the wiring was indeed small. Looked like 16 GA and non-spiral strand(ICBW).
I do want to try this out. Also use two separate wires. And twist them together for about a 7-8 ft run.
Any thoughts on this? TIA!
