G.D.T.R.F.B.
Bare wire sounds best. I find it sounds less "shrouded" than insulated wire.![]()
Bare wire for connections when possible.
Or, the cable just sounded better.....
Maybe he was using 6 gauge inductors.I just saw a set of speakers for sale where the seller was bragging about using 6 gauge wire inside the cabinet to connect the drivers to crossover. SMH. You just can't make this **** up....
Why does sensitivity of 92dB matter?
For the new AVR’s that people use now, there is so much functionality in the circuitry that unless you have great hearing as most people don’t....your not gonna hear the difference. So better cables are only for a small nitch of specific high end audio equipment. The real situation about cables is that no one mentions what equipment that they are using....
Just their opinions....
So better cables only work for people that have great hearing and High priced equipment?
Not being snarky at all (seriously) but you realize that has been the fall back argument for several years as to why many do not experience better sound with higher priced cables?
But the main variable is that many people need a hearing test to see how well they can actually hear the sound first.
The ability to hear a frequency spectrum as in a hearing test is completely different from the ability to hear differences in sonic presentations from gear or wire changes.
Lets say a person finds an unrestored SX-450 and a pair of unrestored HPM-100 (100 Watt version), is the person going to hear a difference on unrestored, bottom of the line equipment ?? Then with people using older equipment that they replace as soon as it burns up with whatever speakers they find....do you really think that they would hear a difference?? There are many that just put equipment together and by trial and error finding a pair of speakers that sound good with an amplifier, of course the crossover in the better sounding pair of speakers matches the power board in the amp and better cables would render a difference. Then with the new AVR’s that have every gadget to include a hookup for the kitchen sink, there is circuitry to compensate at the output of the power board allowing the compensation for the use of different types of speakers and better cables might make a difference. Do you think that out of spec circuitry will yield a difference?? Do you think that we all are at the same place in our experience with an audio experience?? Do you think that everyone on this site continues to look for a top of the line amp or receiver and restores it.....or has it restored along with a high end pair of speakers? No, most people due to historic economic conditions cobble up what they find and it’s far from a match. Those that can afford better or have the tenacity to continue looking for better until they find something that they think has that magically awesome sound. Then only when people find that huge ominous soundstage will better cables make a difference. Most people do not know technically what makes an amp and a pair of speakers match and starting a thread on the matter generally creates more disagreements than cable threads do. So the amount of people that would benefit from better cables are few. But the main variable is that many people need a hearing test to see how well they can actually hear the sound first.
With all due respect....
You make many good points, although they are posed as questions, which obviously I do not truly know the answers to.
I would love to see or even read about a comparison of low priced to high priced cables, where the listener does not have prior knowledge of which is which and can accurately determine one from the other!
Correct, older wire is likely to be pure copper, more modern wire will be copper clad aluminum.Generally speaking old zip cord is better than new zip cord. Why? Better chance of getting copper as opposed to CCA.
Maybe because as said above, only people like you and I having quality modern gear can/will hear a difference?Why is this thread even in The Cutting Edge Forum?
