So I pulled the woofers yesterday and have been doing test runs. The W1208 results are actually very close to the published values from the 1980 catalog, especially considering that they have had the surrounds replaced with non original surrounds. But it surprised me how close the results are. Very promising.
Buffer[1] Vas Ver 7.01
Completed: Wed Jan 21 16:57:28 2015
Drive level 63.096% [686.625 uA]
Sine,LoZP(LV/LA)->Vas,31 pts
Re = 6.1771 ohms
Fs = 21.6312 Hz
Zmax = 40.5763 ohms
Qes = 0.5034
Qms = 2.8035
Qts = 0.4268
Le = 1.7669 mH (at 1 kHz)
Diam = 259.7724 mm ( 10.2273 in )
Sd = 52999.9994 mm^2( 82.1502 in^2)
Vas = 311.8860 L ( 11.0141 ft^3)
BL = 10.7474 N/A
Mms = 69.2624 g
Cms = 781.5909 uM/N
Kms = 1279.4417 N/M
Rms = 3.3579 R mechanical
Efficiency = 0.5892 %
Sensitivity= 89.7206 dB @1W/1m
Sensitivity= 90.8437 dB @2.83Vrms/1m
Krm = 6.130E-03 ohms Freq dependent resistance
Erm = 759.762E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 32.621E-03 Henries Freq dependent reactance
Exm = 664.715E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 14.004 Hz
Ftest/Fms = 0.6474
Test Mass used = 96.0000 g (Equal to 19.2 nickels)
Test Mass (Ft=Fms*0.90) = 16.247 g (Add -79.753g for Ft=19.468)
Test Mass (Ft=Fms*0.75) = 53.871 g (Add -42.129g for Ft=16.223)
And looking at those surrounds again they really don't look like your normal foam. They look something like a cross between rubber and foam. So I contacted the guy that did the surrounds and it turns out that he used santoprene. So perhaps not quite so bad as I had thought earlier.
But on to the ScanSpeak 10". The results baffle me. John, you mentioned that the results for your W1008s showed a very high Q. And funny enough (or not so funny really) my less than 1 year old 10" chassis are geting results that are way off of ScanSpeaks data sheet. I realize that OEM specs are cherry picked and often manipulated, but I'm having a hard time believing that they can be this far off.
Compare the wt2 results...
Buffer[0] Q,Fs Ver 7.01
Completed: Wed Jan 21 19:00:33 2015
Drive level 70.795% [2.083 mA]
Sine,LoZP(LV/LA)->Q/Fs,88 pts
Re = 5.4339 ohm
Fs = 28.3659 Hz
Zmax = 74.4566 ohm
Ro = 20.1084 ohm
F0 = 23.4667 Hz
F1 = 35.1932 Hz
Fmin = 229.0896 Hz
Qes = 0.7049
Qms = 8.9541
Qts = 0.6535
Le = 330.0874 uH @1k
XLe = 7.0276 ohm @1k
PLe = 17.1649 Deg @1k
; Approximate Impedance Fitting Constants ;
; (Improved with Completion of Vas Test) ;
Krm = 2.977E-03 ohms Freq dependent resistance
Erm = 681.232E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 4.903E-03 Henries Freq dependent reactance
Exm = 732.031E-03 Xem=Kxm*(2*pi*f)^Exm
... with the ScanSpeak 25W8565-00 data sheet...
T-S Parameters
Resonance frequency [fs] = 20 Hz
Mechanical Q factor [Qms] = 5.40
Electrical Q factor [Qes] = 0.44
Total Q factor [Qts] = 0.41
Force factor [Bl] = 8.2 Tm
Mechanical resistance [Rms] = 1.00 kg/s
Moving mass [Mms] = 43 g
Suspension compliance [Cms] = 1.47 mm/N
Effective diaph. diameter [D] = 205 mm
Effective piston area [Sd] = 330 cm2
Equivalent volume [Vas] = 225 l
Sensitivity (2.83V/1m) = 88 dB
Ratio Bl/√Re = 3.50 N/√W
Ratio fs/Qts = 49 Hz
Nominal impedance [Zn] = 8 Ω
Minimum impedance [Zmin] = 6.2 Ω
Maximum impedance [Zo] = 73.0 Ω
DC resistance [Re] = 5.5 Ω
Voice coil inductance [Le] = 0.4 mH
So I really don't know what to do with this. But tomorrow I plan on doing a test with both woofers in parallel as if they were a single 15" woofer.
Cheers,
James
