Speakers not working
Hello everyone,
i bought a pair of speakers JBL 305P MKII ....I used Jack trs 1/4 and the other side XLR male, if this is the case what cables should I use instead?
It sounds like you're on the right track, for me when in doubt I usually double check that I'm doing things right
Yup, if you are talking about the sound volume I tried it and nothing happened. It's weird because when I plug them, instead of no sound coming out of both of the keyboard or the speakers, sound plays normally from the keyboard as if I had never plugged them in. How the keyboard works is whenever you plug something in the ports it immediatelly silenceses itself.
I'd probably get a couple 1/4" TS to 1/4" TS cables. That's what the keyboard manual shows for connections.
Yeah, could use TS to XLR, but not really much point IMO since it's not balanced output anyway.
1/4" TS should plug and play fine into the 1/4" TRS input on the speaker.
Can I also buy xlr to ts cable? What difference would there be?
The ones in your picture are TS (as suggested earlier in the thread).
Sorry, I didn't catch the TRS vs TS designation in the cables linked above. TS is apparently what you need. Will edit my posts to correct them to be TS.
The difference would be one end has XLR. There would be no performance advantage.
Personally, I'd probably just keep it simple and get TS to TS cables.
Alright, thanks!. I did not understand the no performance advantage though that you said. The only difference would just be the port it plugs in and nothing else? But it would work just fine?
@BmWr75 @whoaru99 Hello, now that we started the conversation I have another question as well. If I want to plug them into my computer as well which has the usual 3mm jack port, I just need a 1/4'' jack to a 3mm jack cable right? And in order to plug in both of the speakers since I only have one port do I need something like a splitter?
