Speakers with questionable "upgrades"... post your findings here.
Funny enough I am doing a functional cardboard project in class where we laser cut layers of cardboard and use them to create functional furniture or some kind of object that is useful. I didn't think a cardboard speaker enclosure would be on my list but now I'm intrigued.
I built a pair of open-back cardboard enclosures for some 4" x 6" peerless drivers that I had on hand. They certainly deserve a better home but these will have to do for now.
Corrugated cardboard is an underrated enclosure material. I used multiple layers to make a surprisingly rigid yet non resonant enclosure. But I didn't think to brace the walls.
Are these open back, or simply to show what they looked like before sealing them up?
You are surprisingly modest - I don't see where you say that these blow every other speaker out of the water...
It seemed odd to me that Marantz used wood grained vinyl, (and of a different color) on the front baffle rather than the wood veneer they used on the rest of the enclosure. Obviously their drivers were made to be looked at with those fancy Marantz logo trim rings, so grills were not expected to be used.
leesonic - I don't recognize the four ways above. What are they, and which drivers are original? I assume the philips tweeters are, but are the (what look like) KEF midranges original, and if they are, why does one seem to have a second flange around it? And the domes - what are they? And which, if either of the woofers is orginal.
A lot of questions for one post, but inquiring minds want to know...
They were advertised as Rectilinear 5a. A simple search found the 5s pictured below. I don't know these speakers well, but I would guess with you that the only original components are the tweeters. The KEF midrange aren't original, someone could make some money just on these. The big mid-domes don't look original, and I wouldn't be surprised if neither of the woofers are either. Just because the woofer foams rot out, that's no guarantee that they will be replaced with a pair of the same type woofers.
Ah - if I'd seen the original ocatognal basket whizzer mid, I'd have known. I suspect there is some money in the drivers. For some reason I get a Morel feeling about the dome mids.
i looked, and I can't find a Morel mid dome that looks like that, in the suspension/surround around the dome.
I'm guessing that's probably a Vifa/Scan-Speak 3" dome, that someone has modified/ cut down the faceplate to that "rounded square" shape.
Regards,
gordon.
That seems like a lot of work to use with a speaker that has mismatched woofers. But I've done similarly puzzling things.
I was thinking the same thing, that they looked cut down, specifically the one on the right, it looks like the top and bottom "flats" aren't parallel.
Is it just me, or do the KEF mids look like they have damaged cones? To me, it looks like the cones are creased around the dustcaps/cone apex.
Kind of looks like the coating on LS3/5A drivers to me. If those are B110 drivers and they're good, and the price is right, maybe those aren't such a bad deal after all.
I've come across several KEF Bextrene drivers where it appears that the coating is detached at the joint between the cone and dustcap. I don't think it matters. For that matter, my hypothesis about the white area being detached may simply be wrong.
"Older B110 SP1003 often show a white ring around the central dome and these have become known as White Belly LS3/5As. Many enthusiasts believe these White Belly LS3/5As are desireable but it’s one of many urban myths about the LS3/5A. The white ring is indicative of a problem, and is due to the glue delaminating. So it is a fault. As old B110s age the LS3/5A develops a peak in its frequency response at around 1.5kHz. If this peak is only slight it can sound nice and gives the speaker an airy transparent mid-range sound. This may account for why some enthusiasts like older LS3/5As so much. I’ve certainly heard many older LS3/5As sounding lovely, but I have also seen & heard nasty sounding examples where the peak is extreme, sometimes as high as 10dB! Read what Falcon Acoustics have to say about this White Belly Disease."
Leesonic- After all this time/photos you have posted besides starting this thread ( again KUDOS ) it just occurred to me to ask if you run a repair shop or are most of these out in the wild ?
If the latter that is simply crazy.
No, I don't run a shop exactly. It's just my hobby to restore and listen to vintage audio equipment. I get a lot of requests to do restoration work for people, and I do do some. But I only really have evenings and weekends, so my time is limited. Maybe I should retire, and do this full time.
But because of this hobby, I find myself looking at eBay and FB Marketplace for things, and that's where a lot of these pictures show up from.
