If you had\have a phono cartridge up to the task then the C21 would hold an edge in vinyl. Looking at other inputs again if your sources are up to it along with your speakers and ears the edge goes to the C21.
IMHO we are talking apples and oranges since the C21 is limited in scope whereas the Spec 1 will make coffee for you in the morning.....both were heavy hitters in their day.
Here are the numbers:
C21 Specifications:
Frequency response
Phono section was 20 to 20,000 Hz +/- 0.2dB
Aux1 was 10 to 100,000 Hz +0 dB, -0.2 dB
Aux2 was 3 to 300,000 Hz +0 dB, -1.0dB
Total harmonic distortion was 0.01%
Spec 1 Specifications:
Frequency Response
Phono section was 30 to 15,000 Hz +/- 0.2dB
Aux 1 and 2 was 10 to 70,000 Hz. +0/-0.5dB
Total harmonic distortion was 0.03% at 2V output
