jimfet said:There are alot of power amps that can. My stats constantly dip below 2 ohms and I have run them with a Philips a Adcom and a BGW and all are still alive and kicking.
glen65 said:As far as the 2270 is concerned do not use any overall load
under 4 ohms. Ideal impedance for this unit would be 8 ohm. Spec sheet is below.
I've got sooo many goosebumps ????stuwee said:thank You Sir, you are right the 2270 does not like anything under 4ohms, Sid was a Master with the Pre-amp, God how did he hear that s#%t!!?? I've been in awe since I got mine, Pre outed to the SAE A202 AMP![]()
ZR1Brian said:I have a Boston Audio Society (BAS) test report, by Alvin Foster and Wally Swanbon, comparing low-priced receivers and they claimed the GAS Son Of Ampzilla "clattered" and "rang" when driven hard into low-resistance loads. In this case it occured into 2 ohms.
soundmotor said:How were they testing it? Was it into a resistive load box?
SimAudio 4150SE and P 4001 preamp is available for $1000 in our local area. I’m also planning to get an LRS as well. I’m wondering if these gears match musically and since both are very transparent, won’t it be too bright or harsh at the top end?Simaudio Celeste 4150SE
This beauty can drive just about anything without breaking a sweat and is an exceptionally musical amp. If you can get one buy it!!
r-117 does 700wpc @ 2 ohms
To deliver 2000 watts, it's going to consume more than double that. Per channel.effing 'ell, man! What sort of power draw does it take to make 2000 watts in Class A!?!
Must need three-phase AC to run the thing!
20A isn't even close to what you need.120V, but they suggest a 20A service.
